Yard Hydrant - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2010, 12:06 PM   #1
yard hydrant
Hi
I just finished installing a new Campbell FrostproofYard Hydrant and turned the water on from the house and we get water coming out of the drain hole but none out of the faucet
cindyc123 is offline   Reply With Quote
Old 12-05-2010, 12:21 PM   #2
the Musigician
DangerMouse's Avatar
Hi Cindy. Welcome to the forum.
Drain hole? On the faucet?
DM
Old 12-05-2010, 12:37 PM   #3
yes. It's set up like a fire hydrant.There is a drain hole at the botom of the 6 foot pipe that is burried. That is to prevent the water from freezing
Old 12-05-2010, 01:23 PM   #4
the Musigician
If it's buried, how do you know it has water coming out?
DM
Old 12-05-2010, 01:43 PM   #5
Licensed Master Plumber
The hole is the waste and it's job is to drain downs the pipe that is above the frost level. However it sounds like the lever in the valve body is not closing the waste and that type of yard hydrant can not legally be installed unless it has a backflow preventer attached to the inlet
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 12-05-2010, 04:46 PM   #6
Cindyc,
I think the problem is more like you need a rebuild kit for it, not sure who the manufacturer is but if you go to where it was purchased they should have parts or the ability to order them. One thing you can try is to shut off the water. Remove the head from the yard hydrant. Have someone turn on the water. Let the water run through the hydrant for a few seconds 5-10. then turn off water reassemble unit and see if problem corrects itself. It is possible that either the plunger is damaged or has debris in it. Disassembling and reassembling it may correct it.
Sorry They are correct you should not have it installed if its use is for potable (drinkable water) However if it is for utility then there is no need for a backflow preventer. The worry is that when the unit is drainning it can actually pull the drained water back into the water supply if there is a vaccuum pulled on it.
If flushing the unit doen't work then you need a rebuild kit and it should correct the problem.
Work4living is offline   Reply With Quote
Old 12-05-2010, 06:31 PM   #7
yard hydrant
This is a brand new Campbell unit. I am wondering if there is something that needs to be adjusted.
Old 12-05-2010, 06:33 PM   #8
This is being used in a barn
Old 12-05-2010, 06:39 PM   #9
If it is connected to your water system ( the same well and piping that feeds your house ) it must have a BFP, especially in a barn yard area where feces and god knows what else could end up in your water system.
If the hydrant is brand new I would dig it up and take it back, something is jammed under the waste seat.
Old 12-05-2010, 07:59 PM   #10
Picky Plumber
Likely you just need to adjust the linkage... the rod that goes into shaft @ hand should have an adjustment on it....
Plumber26 is offline   Reply With Quote
How to Grade Forever-Flooded Yard? TheMedicsWife Landscaping & Lawn Care 1 04-12-2010 11:46 AM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 10:03 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 07:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 12:55 PM
Well Water ? - No water at yard hydrants... but do have water in house mntnvew Plumbing 73 01-11-2010 08:45 PM
