Y U Install Unions/shut Off On A HWH - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-19-2013, 09:06 AM   #1
biggles's Avatar
Y U install unions/shut off on a HWH
so when it takes a dump years later ..you don't have to torch hot /cold? fittings out .. fittings in...2 beer job on a Saturday afternoon flushed this guy since 1989 every fall
The Following 2 Users Say Thank You to biggles For This Useful Post:
ddawg16 (11-19-2013), TheEplumber (11-19-2013)
Old 11-19-2013, 09:14 AM   #2
Rewards Points: 13,300
There should never be a shut off on the hot side.
Good luck trying to get a gate vale to stay closed and not leak by while your working on it.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
Javiles (11-19-2013), plummen (11-19-2013)
Old 11-19-2013, 09:16 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
Why not?
Old 11-19-2013, 09:30 AM   #4
Valve reqd on cold-water supply at or near WH____[2903.9.2] {605.2}n Valve must be full-bore type F41,42_______________[2903.9.2] {605.2
Old 11-19-2013, 09:38 AM   #5
Plumber
Rewards Points: 452
Biggles- seen a lot of Kenmores last a long time- especially when you flush and maintain them like that. I like the record keeping system
I know they're required on the supply side. All equipment and fixtures require approved unions and valves.
Old 11-19-2013, 10:06 AM   #6
I guess the logic is some one shuts off the hot side, thermostat fails and pressure continues to build.
Old 11-19-2013, 11:14 AM   #7
raylo32's Avatar
Rewards Points: 1,240
But even w/o valves pressure would build anyway--until it fully compressed the bladder in any expansion tank-- before the P&T finally lifts. I have valves on both sides of mine. Makes replacement truly a 2 beer job since don't have to drain hot and/or cold water lines for 3 floors.. and then have to vent and refill them all..
Live long and prosper.
raylo32 is offline   Reply With Quote
Old 11-19-2013, 11:25 AM   #8
Rewards Points: 228
Nice set-up biggles. Quick and easy to swap out. Next time you have to replace it, in the interest of future proofing, I would replace those gate valves with ball valves. Just a thought.
jmon is offline   Reply With Quote
Old 11-19-2013, 05:01 PM   #9
biggles's Avatar
I drain it into a 5 gallon bucket to see what drops down as it drains to see what it gives up every year.some rust that looks like sand once in a while.the trick with the unions.... if the pipes come in on the horizontal they are liberal to the new HWH refit.if they drop down in a fixed mounted vertical drop you have to be more careful,and pop that relief randomly thru the year
Old 11-19-2013, 08:47 PM   #10
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Originally Posted by TheEplumber View Post
Why not?
Its ilegal around here to install shut off on hot water side of heater around here.
I saw the results of a capped off pop off valve on a house south of here years ago,pushed a really big piano into the head board of a bed when nobody was home(lucky for them).
Its considered bottling ,if the pop off doesnt give and that valve gets shut by a home owner for some reason it can be really ugly.
We also demonstrated it on a water heater in the middle of a field back when I still taught.
Plugged the pop off then filled heater with water and put pipe plugs into top of heater to bottle it.
Put a coleman stove under it and let it cook for around 30 mins while we watched from a telescope,cleared the top of the tree line and hung a left turn across the field.
The class was impressed!
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 11-19-2013, 09:11 PM   #11
Plumber
Rewards Points: 452
YouTube has several exploding WH videos They're entertaining to watch for sure.
I was just messing with Joe earlier. I can't recall putting two valves on a residential heater but have done so many times on commercial applications- never been called on it when inspected by the plumbing inspectors, engineers or even the corp of engineers at military sites.
I totally understand the reasoning behind bottling and as the code says- AHJ has the final say.
I can pipe my T&P's outside- which I understand is not allowed in other areas. But we cannot pipe it to the pan.....
The minor list of code differences goes on and on.......
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 11-19-2013, 09:51 PM   #12
biggles's Avatar
opinions on hard piping the HWH off the supply,HD sells the flex lines as HWH lines then my gas company National Grid condems them
Old 11-19-2013, 10:14 PM   #13
plummen's Avatar
I always kind of grouped the flex copper water heater lines in with trac pipe,green field/flex......
Of course i still remember some of the older guys I worked with as a kid complaining about that damn new fangled thin walled e.m.t conduit,saying it would never be as good as rigid pipe!
The Following 2 Users Say Thank You to plummen For This Useful Post:
oh'mike (11-20-2013), TheEplumber (11-19-2013)
Looking for help on how to install recessed soffit. Snoopy_ Roofing/Siding 2 09-04-2012 04:45 PM
Oak stair tread and riser install tips MTWI Carpentry 6 05-04-2012 06:46 PM
How To Install a Chimney Liner Rockford How To Guides 0 01-24-2012 11:00 AM
Aprilaire 560 Install Questions MisterTFM HVAC 4 12-15-2011 01:35 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
