-   -   Y U install unions/shut off on a HWH (http://www.diychatroom.com/f7/y-u-install-unions-shut-off-hwh-190630/)
biggles 11-19-2013 08:06 AM
so when it takes a dump years later ..you don't have to torch :wink: hot /cold? fittings out ..:thumbsup: fittings in...2 beer job on a Saturday afternoon http://i275.photobucket.com/albums/j...ps841f030d.jpgflushed this guy since 1989 every fall
joecaption 11-19-2013 08:14 AM
There should never be a shut off on the hot side.
Good luck trying to get a gate vale to stay closed and not leak by while your working on it.
TheEplumber 11-19-2013 08:16 AM
199 Attachment(s)
Why not?
joecaption 11-19-2013 08:30 AM
Valve req’d on cold-water supply at or near WH____[2903.9.2] {605.2}n Valve must be full-bore type F41,42_______________[2903.9.2] {605.2
TheEplumber 11-19-2013 08:38 AM
199 Attachment(s)
Biggles- seen a lot of Kenmores last a long time- especially when you flush and maintain them like that. I like the record keeping system:wink:
I know they're required on the supply side. All equipment and fixtures require approved unions and valves.
joecaption 11-19-2013 09:06 AM
I guess the logic is some one shuts off the hot side, thermostat fails and pressure continues to build.
raylo32 11-19-2013 10:14 AM
But even w/o valves pressure would build anyway--until it fully compressed the bladder in any expansion tank-- before the P&T finally lifts. I have valves on both sides of mine. Makes replacement truly a 2 beer job since don't have to drain hot and/or cold water lines for 3 floors.. and then have to vent and refill them all..
jmon 11-19-2013 10:25 AM
Nice set-up biggles. Quick and easy to swap out. Next time you have to replace it, in the interest of future proofing, I would replace those gate valves with ball valves. Just a thought.
biggles 11-19-2013 04:01 PM
I drain it into a 5 gallon bucket to see what drops down as it drains to see what it gives up every year.some rust that looks like sand once in a while.the trick with the unions.... if the pipes come in on the horizontal they are liberal to the new HWH refit.if they drop down in a fixed mounted vertical drop you have to be more careful,and pop that relief randomly thru the year
plummen 11-19-2013 07:47 PM
Originally Posted by TheEplumber (Post 1268662)
Why not?
Its ilegal around here to install shut off on hot water side of heater around here.
I saw the results of a capped off pop off valve on a house south of here years ago,pushed a really big piano into the head board of a bed when nobody was home(lucky for them:eek:).
Its considered bottling ,if the pop off doesnt give and that valve gets shut by a home owner for some reason it can be really ugly.
We also demonstrated it on a water heater in the middle of a field back when I still taught.
Plugged the pop off then filled heater with water and put pipe plugs into top of heater to bottle it.
Put a coleman stove under it and let it cook for around 30 mins while we watched from a telescope,cleared the top of the tree line and hung a left turn across the field.
The class was impressed!:laughing:
TheEplumber 11-19-2013 08:11 PM
199 Attachment(s)
YouTube has several exploding WH videos :thumbup: They're entertaining to watch for sure.
I was just messing with Joe earlier. I can't recall putting two valves on a residential heater but have done so many times on commercial applications- never been called on it when inspected by the plumbing inspectors, engineers or even the corp of engineers at military sites.
I totally understand the reasoning behind bottling and as the code says- AHJ has the final say.
I can pipe my T&P's outside- which I understand is not allowed in other areas. But we cannot pipe it to the pan.....
The minor list of code differences goes on and on.......
biggles 11-19-2013 08:51 PM
opinions on hard piping the HWH off the supply,HD sells the flex lines as HWH lines then my gas company National Grid condems them
plummen 11-19-2013 09:14 PM
I always kind of grouped the flex copper water heater lines in with trac pipe,green field/flex......
Of course i still remember some of the older guys I worked with as a kid complaining about that damn new fangled thin walled e.m.t conduit,saying it would never be as good as rigid pipe!:laughing:
