Is This XH Or SVC Grade Cast Iron Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-23-2012, 09:50 AM   #1
Question
Is this XH or SVC Grade Cast Iron Pipe?
Can anyone identify the cast iron drain piping in the photos below? I'm trying to determine if they are "Service Grade", or "Extra Heavy" grade. I need to replace the lead pipe, and as I understand it, XH vs SVC will make a big difference in my course of action. I cannot see any markings on the pipe at any point which indicate which type it is. The "T" junction pictured has "3859" on the side. Thank you for looking.
SVC or XH Cast Iron (?):
vrflp is offline   Reply With Quote
Old 10-23-2012, 11:12 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Can't tell by looking at it unless you can see "SV" stamped on the fitting or pipe. The numbers you referenced are probably the fitting's catalog #. You need to measure the OD to be sure. However, since this is in a house I'll bet its SV No reason to have used for extra heavy
Old 10-23-2012, 11:28 AM   #3
Thank you for your reply. I do not see anything related to SV or XH stamped on any parts of the pipe that are visible. I do not feel any raised or embossed lettering on the side I cannot see.
The house is about 60 years old. Can I safely assume the chart below would apply for measuring the OD?
http://www.engineeringtoolbox.com/ca...ns-d_1751.html
vrflip is offline   Reply With Quote
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 06:54 PM
pouring concrete around cast iron pipe? walkman Plumbing 1 10-16-2009 11:04 AM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
