Wye Vs. Sanitary Tees - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-26-2008, 01:05 AM   #1
Wye vs. Sanitary tees
I recently completed a kitchen remodel with exception to laying the flooring, while filling/draining my sink I noticed a leak from the wall . I opened the wall up and found that the pipe just below of the sanitary drain was cracked. My question is can I use a wye vs. a sanitary tee to tie in the sink drain, vent pipe and the drain line. I have very limited space to make it work and cannot pull the cabinets due to a recent granite top install.
gsgtree is offline   Reply With Quote
Old 11-26-2008, 09:55 PM   #2
skyman's Avatar
Yep, put a street 90 in it, and you should be good.
skyman is offline   Reply With Quote
Old 11-26-2008, 10:46 PM   #3
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If you use a wye/street 45 combo what you are effectively doing is choking off your vent. A tee would be a better fix. However, you'd probably be ok with the wye. I'd oversize the fixture arm if possible to 2" then reduce down to 1-1/2" using a bushing right where it 90s out of the wall.
JDC is offline   Reply With Quote
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 08:10 PM
Closely spaced tees on primary loop Mike Warner HVAC 1 04-18-2008 12:30 AM
Your opinions on slip Tees 1nonly Landscaping & Lawn Care 3 04-22-2007 11:47 PM
Ok to use a sanitary cross in a wet vent? peeks Plumbing 1 10-03-2005 05:35 PM
