Old 04-29-2013, 07:45 PM   #1
WYE fitting question
I noticed a WYE fitting with a side inlet on it. Is that for a vent line or to tie in another drain into?
markharmon is offline   Reply With Quote
Old 04-29-2013, 10:29 PM   #2
Master Plumber
Javiles's Avatar
is this the fitting your referring too?
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Old 04-29-2013, 11:11 PM   #3
Yes that is it. What is that inlet used for?
Old 04-29-2013, 11:52 PM   #4
Master Plumber
Javiles's Avatar
Its actually a tee not a wye and depending on the configuration of the plumbing fixture group or system set up it could be used in multiple applications.
Old 04-30-2013, 08:46 AM   #5
Ok but I am asking what the inlet part is for?
Old 04-30-2013, 10:16 AM   #6
As javilles has stated it can be used for multiple applications. For example, the side inlet can be use as a Drain, Vent, or Waste depending on what, where, and how you are going to be using it. Before using one of these, please check plumbing code for your area. You may or may not be able to use inlet for certain applications. I'm not sure.
jmon is offline   Reply With Quote
Old 04-30-2013, 10:22 AM   #7
Doing it myself
Alan's Avatar
Side inlet fittings last I checked are not legal under UPC.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
jmon (04-30-2013)
Old 04-30-2013, 10:24 AM   #8
I was just wondering what it was used for. I also saw a combination Tee Wye. When are those typically used?
Old 04-30-2013, 10:27 AM   #9
Doing it myself
Alan's Avatar
Today would be a good day to use it, I think.
Journeyman Plumber
fetzer85 (05-01-2013)
Old 04-30-2013, 02:19 PM   #10
So, you don't want to answer that last question?
Old 04-30-2013, 08:24 PM   #11
I believe plumbers refer to those as just combination wye's, combination tee's, or just comby's. I know at the big box stores sales reps call them combination tee-wye and they are listed as combination tee-wye. Terminology can vary, depends who you ask. They can be used for Drain, Waste, and Vent applications. Required in some plumbing code areas to connect a branch line into a vertical drain pipe instead of a conventional tee fitting.
You refering to something like this?
link here
Old 04-30-2013, 11:06 PM   #12
link here
Yes that is it. Why not just use a regular san tee instead of this? Since its a combo tee-wye can it be placed on its side like a WYE?
Old 04-30-2013, 11:31 PM   #13
Master Plumber
Javiles's Avatar
Combo and wye are basically the same thing, sanitary tee is completely different animal in its use and application. what are you trying to do maybe easier this way,
Old 05-01-2013, 10:54 AM   #14
Always learning...
fetzer85's Avatar
The problem is it seems like you're using this site as a literal classroom. You continually open threads with a generic line of questioning and every time you post you add more questions. I offered to mail you a framing book for free if you PM'd me your address because you told us you don't have $4.50 to spare, yet you never gave it to me. So YES, we're frustrated! Please either make threads about a specific project you're working on or take your own time to do the studying & research necessary to understand the things you're repeatedly asking about.
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
Javiles (05-02-2013)
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 11:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 09:30 PM
Fitting Door Closers clayton1302 Carpentry 6 05-09-2009 09:09 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
