Wrecking Out Drain Line & Supply Lines - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-26-2013, 11:43 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 684
Clean out the concrete debris and pour back concrete using bag mix. You need a solid base for the tub.
It's best if you determine which water lines at the manifold are abandoned and cap them there- just below the header tee- not under the tub.
Old 06-27-2013, 12:14 AM   #17
E, Did you see my post that I did earlier where I used your quotes a couple of times and responded to them?
Also, what do you mean "just below the header tee"? If you are talking about just above the bottom plate in that one picture, the line that is all by itself is a cold line supplying the old shower, I will use it in the new supply to the new tub/shower. Of the 3 lines that are all tied together, these are hot lines, one goes down to the old tub, but then it goes over and feeds the sinks, so I can't cap it off. I can basically cap that one under the tub above the slab, or I can cap it off below the slab. It just seems like if I ever had to fix a leak beneath the slab, it would be worse than fixing one just under the tub. On the manifold at the bottom plate, the other two lines that go down in the concrete, I believe these go off to another part of the house to feed other fixtures.
greghamilton is offline   Reply With Quote
(Louisiana) What size pipe Sewer, Drain and fresh water supply lines cmb7684 Plumbing 0 04-23-2013 05:54 AM
Install new faucet with compression fittings to larger copper supply lines cwb124 Plumbing 7 02-27-2013 04:11 PM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Supply line sweating above one piece tub/shower combo joatman66 Plumbing 0 01-13-2012 10:33 AM
Water supply line blackhemi Plumbing 4 04-09-2011 08:18 PM
