Would You Trust Sharkbite For Shower, Dropear Behind Wall? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-19-2008, 06:04 AM   #1
Rewards Points: 150
Would you trust Sharkbite for Shower, Dropear behind wall?
I am installing my mixing valve and would like to use a sharkbite for the dropear and where the copper meets the valve on the shower riser. Do you guys think it is safe to use behind the wall with tile being installed after? I don't want to have to remove the tile 5 years from now because of the fittings but I would like to use them if they are reliable. THanks.
twilightcall is offline   Reply With Quote
Old 08-19-2008, 09:19 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I don't understand the purpose for using a sharkbite fitting. If it's completely necessary, I would trust it, but our shop owner would never allow something like that. Why not just solder it?
Journeyman Plumber
Old 08-19-2008, 09:42 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
I agree. we used a shark-bite on a temp relocation from a wall that was removed and found that it leaked. I would not trust them behind a wall that is going to be closed. I would agree soldier on a cap. BOB
Old 08-19-2008, 10:14 AM   #4
Being an "old school" plumber, I would not use it. It is a form of compression fitting and codes I have worked under do not allow a compression fitting where it cannot be "readily seen". This includes inside walls and in crawl spaces.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-19-2008, 11:29 AM   #5
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Sharkbite says they are "approved" for concealed locations but I agree with almost everyone else and would be hesitant to use one in this application, since it is pretty easy to solder on a coupling. That being said, I am a big fan of Sharkbites, just not in this case.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Old 08-19-2008, 03:15 PM   #6
buletbob's Avatar
Yes I agree. there are 3 towns that will not allow them in any concealed location.
Old 08-19-2008, 04:19 PM   #7
Registered User
Termite's Avatar
Although they may be appropriate for concealed locations, SharkBite fittings haven't received ICC code approvals to my knowledge. So, many jurisdictions do not recognize or allow them.
Personally, I like them. I don't see any reason to use them in this application though.
Old 08-19-2008, 04:27 PM   #8
Send a message via AIM to Marlin
I've seen shark bite fittings used once. Of ten installed one leaked. I will not use them.
Marlin is offline   Reply With Quote
Old 08-19-2008, 06:44 PM   #9
Sharkbite fittings take me back a number of years when everyone thought Poly pipe was the greatest thing ever made. Until it failed miserably. I guess you just have to use common sense and before installing something inside a wall, figure out what will happen if it fails.
Old 08-19-2008, 09:11 PM   #10
buletbob's Avatar
there great to use as a remodeling contractor,when gutting an bathroom remodel, but never hidden in a wall, I have had 1already fail on me . your call. BOB
Old 08-22-2008, 08:21 AM   #11
Rewards Points: 150
Thanks guys. I will go with copper. I haven't sweated copper in a long time but I will do my best and leave the wall open for a few days and make sure there are no leaks. Does that sound good? Pex is coming in for the supply and copper will be used for the stub out and the shower.
Old 08-22-2008, 09:11 AM   #12
Doing it myself
Alan's Avatar
thats exactly what we do on pex houses.
Journeyman Plumber
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
