-   -   Would you replace these valves under the sink? (picture) (http://www.diychatroom.com/f7/would-you-replace-these-valves-under-sink-picture-172746/)
addfsd 02-23-2013 05:23 PM
1 Attachment(s)
Hi everyone,
I'm embarking on a little project - replacing my kitchen sink. I'm going to post a couple questions to get started, and I plan to come back and post a photo of the completed results.
These are the hot/cold valves. They haven't been shut off in 25 years. The left (hot water) one looks pretty horrible. Should I bother replacing them since I'll be in there anyway, replacing the sink? Thinking about buying a mini pipe cutter and cut them clean off right below the soldered piece. Replace with a couple shiny brand new compression valves.
Is it as easy as I imagine? Any soldering involved, or will the compression valves do the trick?
Thanks!
TheEplumber 02-23-2013 05:28 PM
199 Attachment(s)
Buy a pair f 5/8 x 3/8 compression straight stops. You can cut the copper below your existing valves to install the compression stops- no soldering.
joecaption 02-23-2013 05:40 PM
Just clean off the pipe before even trying to cut it.
A strip of sand paper will work.
Also get yourself two new stainless steel flex lines for the supplys.
Make sure to measure before buying they come in a lot of differant lengths.
addfsd 02-23-2013 06:04 PM
Thanks.
addfsd 02-23-2013 06:05 PM
Thanks. I didn't even think to measure those since they are flexible. Good catch.
oh'mike 02-23-2013 06:27 PM
Use the better 1/4 turn ball valves---those ones like you have there can't be trusted when they get old.
Brass Craft brand are good----go to the Home Depot for them.
funfool 02-23-2013 06:34 PM
I would not consider keeping them. The one on the left has been leaking for a long time, it may be such a small drip that it dries before hitting the ground, but it has leaked or still is leaking now.
You will find that you may not be able to turn the water off with those valves.
They work great when new, but then they sit there for years without being opened and closed. When you do need them to work, quite often they will not seat all the way and still drip after you close them, to remove the supply lines to the sink.
This is why you want to update the valves to 1/4 turn.
JDC 02-23-2013 10:06 PM
yes, I would replace them.
addfsd 03-01-2013 04:46 PM
1 Attachment(s)
I can't find 5/8 x 3/8 anywhere. I can only find 1/2 x 3/8 like this:
Link to 1/2 x 3/8 HD valve
Home Depot had a giant display of these, so I assumed this size was the most common. Did I get the wrong ones?
TheEplumber 03-01-2013 05:25 PM
199 Attachment(s)
Should work. I'm in the habit of saying 5/8 OD because there is a 1/2" OD copper tubing (rigid pipe like yours is 5/8). Been screwed on parts orders too many times:furious:
addfsd 03-01-2013 06:06 PM
Just measured the opening and it's 5/8". Why it's labeled 1/2", I'm not sure but you are absolutely correct, these will work! I'm pumped to get started on this early tomorrow morning.
jagans 03-01-2013 06:27 PM
Pipe is measure by its ID, not its OD. You are going to do something with that dishwasher hose right?
TheEplumber 03-01-2013 07:23 PM
199 Attachment(s)
:eek:
addfsd 03-01-2013 07:48 PM
Well, I think in a few weeks, I'm going to get rid of the dishwasher and install a cabinet. We don't use that appliance and I don't plan on selling this home. I know that's strange to hear.
Is teflon tape necessary on compression valves?
addfsd 03-01-2013 07:51 PM
Nevermind, I see that's a no-no.
