Would This Be A 'P' Trap Or An Illegal 'S' Trap? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-05-2012, 11:20 PM   #1
Would this be a 'P' trap or an illegal 'S' trap?
I'm draining a reno bathtub connection, 1 1/2 inch into an existing cast 'T' which is a vent above the 'T' joint. Yes, I know the joint is a sani-T , but that's life without replacing the whole thing drain/stack combo. The reno drain is a standard 1 1/2 inch ABS tub/overflow drain kit. Limited room means: the kit allows for the overflow and tub drain to connect with the proper sani-T, then after this becomes the lack of room. Can I come off the bottom of the T with a 90 elbow, outlet at the horizontal, then immediately connect another 90 down to the P trap, outlet the P trap with the horizontal 90 the P trap comes with and immediately (horizontally) into the old cast T into the vented vertical drain pipe? The only plumbing above this connection is the remainder of the cast pipe which is only a vent/stack connecting to the main stack and no other 'drain'. A plumber said this would not pass inspection, but again, it is not a conventional illegal S trap.
klondiker is offline   Reply With Quote
Old 04-05-2012, 11:32 PM   #2
To clarify,maybe, the 2 ABS 90's takes me a bit further away from the cast T fitting in order to make enough room for the modern ABS P-trap, then drops about an inch into the P trap. The cast T has a male thread fitting onto which I've ABSed a thread to ABS glue fitting. The plumber's concern was for the two 90 elbows coming off the tub sani-T, then down into the P-trap, thus making an 's' trap in his opinion.
Old 04-06-2012, 12:07 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 562
maybe because I'm tired-- but you lost me half way through If you are not putting 90's pointing vertical between the trap and vent (trap arm) you are ok-
Can you supply a picture?
Old 04-06-2012, 09:25 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Tailpiece : Piping coming from the fixture outlet into the p-trap. This must stay vertical. Our plumbing code allows us to be at 45* and still be vertical.
Thus your two 90* offsets before the inlet of the p-trap would be a violation.
I wouldn't call it an s-trap, maybe more like a running trap but nonetheless it still isn't correct.
Journeyman Plumber
Old 04-06-2012, 10:08 AM   #5
Thx guys. No pic available, I already took out the tailpiece to start fresh. What I need is to shift the tailpiece off center of the tub to the right to allow room to connect the P trap to the outlet T. So, I start with the P-trap connected to the stack. It sounds like, Alan, that I could get tailpiece alignment by installing two 45's in the vertical pipe between the overflow and the sani-T coming from the tub drain, then turning the horizontal drain run and sani-T to the right to line up with the offset overflow pipe. The new configuration would be such that the tailpiece would line up still vertically with the P-trap that would already be connected to the T in the stack. Correct?
Old 04-06-2012, 02:32 PM   #6
Plumber
Rewards Points: 562
What exactly is in your way? I still have a hard time picturing your set up
I have configured waste and overflows different ways.
There is nothing wrong with making the outlet drain piping horizontal before dropping into the trap. In reality, you're just lengthening the tub shoe. Picture a continuous waste under a kitchen sink. it has 90's and horizontal pipe before the trap
Old 04-06-2012, 10:09 PM   #7
Doing it myself
Alan's Avatar
I have had to do that before due to floor joists being centered on tub drain. Offsetting the overflow is the easiest way to get around it. Is it impossible to put a new p-trap in where it needs to be?
Journeyman Plumber
Old 04-06-2012, 10:18 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Sounds like a running trap to me from what your describing anyway
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
Alan (04-06-2012)
Furnace condensate drain/trap issue SteveC HVAC 33 12-27-2012 11:46 AM
Trane XR90 - Condensate Drane Trap JDWorks HVAC 16 02-07-2012 07:59 PM
kitchen wall drain outlet higher than trap arm Druidia Plumbing 24 10-13-2011 12:39 PM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
