Worst Metal For Calcium Deposits - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2013, 07:01 AM   #1
worst metal for calcium deposits
Hi I was just wondering if anyone knows what kind of metal is most conducive to calcium deposits? For instance, steel, copper, etc. And what exactly causes calcium deposits/lime buildup?
pigfart is offline   Reply With Quote
Old 01-24-2013, 07:29 AM   #2
Rewards Points: 14,306
Why are you asking?
If you get the water tested and figure out what's wrong with it you can treat it before it ever gets to the plumbing.
One place it's really going to cause issues is in the water heater. It can build up on the bottom of the tank and short out the element, take longer to heat the water, make all kinds of noises as it pops off when heating, shorten the life of the heater.
Old 01-24-2013, 07:44 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,726
Ayuh,... The build up, comes from minerals in yer water supply,...
It'll build up on anything, metal or otherwise...
Bondo is online now   Reply With Quote
Tags
calcium , deposit , material , metal
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Paint for Rust-Prone Exterior Metal Railings (Oil-Based Metal vs Epoxy vs Urethane) Einhorn Painting 9 06-19-2011 08:41 PM
Replacing metal box caused issues rivers001 Electrical 28 03-07-2011 12:21 AM
I'm New & Need Help With Metal Shower Trim dawn312 General DIY Discussions 2 06-06-2009 01:43 PM
Standing seam metal in NJ pcampbell Roofing/Siding 1 05-12-2009 07:10 PM
