Worn Out Sink Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2011, 02:31 PM   #1
Exclamation
Worn out sink drain
I have an ancient sink drain that finally disintegrated. The P-trap and drain extension literally fell apart to the touch. The problem is 1) it's all copper pipe 2) the drain extension appears to have been welded onto the iron stub-out.
The question is 1) how do I remove all this and 2) how can I attach PVC pipe to the stub-out (which apparently has no threads).
Any help is greatly appreciated!
babyc is offline   Reply With Quote
Old 03-22-2011, 05:20 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture if you can-----It sounds like a rubber Fernco fitting might be a quick solution if you don't have soldering skills or equipment.
Old 03-22-2011, 07:57 PM   #3
Worn out sink
Here is a picture of my drain problem.
Thanks for your time!
Old 03-22-2011, 08:21 PM   #4
DIY staff
That's soldered in----easiest thing to do is saw that off --add a rubber Fernco boot--then a PVC trap adapter-- then the usual plastic P-trap.
A trap adapter is a fitting (1 1/2") that has a nut and is usually glued into a fitting.
Best and correct way to fix that would be to solder on a 1 1/2" copper male fitting. Bring your wallet--the last one I bought was over $20-- Mike
Old 03-22-2011, 08:59 PM   #5
Worn out sink drain
Thanks!!!
But can't I just saw off the mess and use a Fernco coupling and a PVC drain extension/P-trap?etc... instead of soldiering a copper pipe and end up just adding a coupling and doing the same thing?
Old 03-22-2011, 10:46 PM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 566
Originally Posted by babyc View Post
Thanks!!!
Yes you can. Thats what Mike suggested.
Use a fernco(copper x plastic), 1 1/2" plastic trap adapter, and a p trap- Done deal
The Following User Says Thank You to TheEplumber For This Useful Post:
oh'mike (03-23-2011)
Old 03-23-2011, 10:04 AM   #7
Worn out sink drain
Thank you.
Tags
copper pipe , iron stub-out , p-trap , sink drain
Help with sink drain. Steve S Plumbing 10 11-09-2009 01:42 AM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 08:36 PM
Sink won't drain kchopper Plumbing 5 06-07-2009 09:42 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 08:36 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
