Old 12-28-2012, 03:55 PM   #1
Working with PEX pipe
I bought a 100' roll/coil of 1/2" pex pipe at my local home improvement store for a basement bath. When I released the strapping holding the roll/coil together it stays coiled up and seems like it might be hard to work with that way. My question, Is there a secret to getting this pipe to "unwind" straighten out?
natspawpaw is offline   Reply With Quote
Old 12-28-2012, 04:02 PM   #2
#1 Your going to need 3/4, not 1/2" for the main supplys all the way to the fixtures then step it down to 1/2.
100' of 1/2 could do a whole house or 2.
Make sure the pipe has time to warm up then bend it backwards as you take it off the roll.
Old 12-28-2012, 04:05 PM   #3
So the rest of us can learn, what if the OP uses a manifold system. Can they use 1/2" supply? If so, so it matter the distance the fixture is from the manifold?
B
Beepster is offline   Reply With Quote
Old 12-28-2012, 04:39 PM   #4
It’s a pita to have to straighten that much pex. You can get straight lengths from 10’-20’
epson is offline   Reply With Quote
Old 12-28-2012, 04:55 PM   #5
B
This is coming off a 3/4 manifolds (hot & cold) to individual fixtures approximately 25' from manifold, 5 lines total 1/2" pex to shower, sink, & toilet.
Old 12-28-2012, 05:10 PM   #6
Civil Engineer
PEX is easy to straighten, you simply warm the pipe up and uncoil it gently in reverse. Or you can run warm water through it to make it less stiff very quickly. I work with 300 foot lengths, simply uncoil what you need, straighten gently, then cut with a tubing cutter.
As to sizing, if you have a manifold system, you can probably use 1/2 inch for all the runs.
Old 12-28-2012, 05:10 PM   #7
Master General ReEngineer
Bondo's Avatar
Ayuh,... That 1/2" stuff can be pushed, 'n pulled as ya please, 'n stays put just Fine, After ya secure it...
Just pay mind to the pitch of the pipe, so's ya ain't fightin' the twist...
The Effort to get the stuff, In-place, goes up with the diameter,...
Old 12-29-2012, 05:25 PM   #8
I bought two rolls of that pex pipe. Now i just buy the straight pieces. And that gas line roll that is huge, oh man, that stuff is something else.
paintdrying is offline   Reply With Quote
Cutting and gluing PVC pipe to washer steve3847 Plumbing 8 10-03-2012 09:00 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 10:23 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Is yellow polyethelene or polyphenol gas pipe now the preferred gas conduit? MarkSilber Plumbing 1 09-18-2010 01:10 PM
