Working With Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-18-2010, 01:02 PM   #1
Working with pex
I know this sounds lame, but I just bought a coil of pex tubing and am having difficulty 'unwinding' it to get it straight enough to use. Any suggestions?
diditforme is offline   Reply With Quote
Old 11-18-2010, 05:28 PM   #2
Rewards Points: 150
This is a picture of a pex unwinder, you might be better off trying to make one,they are not cheap.
braindead is offline   Reply With Quote
Old 11-18-2010, 05:31 PM   #3
That looks a lot like a romex or BX unwinder. They are sometimes expensive but you can find them cheap. A lot of electrician make their own.
Lockeset is offline   Reply With Quote
Old 11-18-2010, 05:53 PM   #4
We would drill a hole big enough for a small piece of all thread (or if it was steel studs just put a piece of all thread in one of the open spots) and put the roll in their. Then when we pulled on it we would bend it backwards to straighten it a little. It was almost impossible to do when it's cold though. Good luck with it.
immeraufdemhund is offline   Reply With Quote
Old 11-18-2010, 07:44 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
I've read where one guy secured one end of the pex tubing, unrolled the tubing using one arm as an axle and let it sit in the sun for a while to let it straighten out. Then it was easier to install.
FWIW, that's what I plan to do when I install our pex lines. I have a 2' length of 3" ABS pipe and will stick a 3/4" galvanized pipe through it. My friend and I will each hold one side of the pipe and unroll the amount of pex to be installed. Let the sun help straighten it out and then run it through the attic. That's my plan anyway but have yet to see how it works.
Don't know if you will have any hot sunny days where you're at this time of year but if so, maybe this idea will help you out.
HRG
Homerepairguy is offline   Reply With Quote
Old 11-18-2010, 09:54 PM   #6
Licensed Master Plumber
Leave it out in the sun for a couple of months. that will soften it up
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 11-18-2010, 10:32 PM   #7
great advice from pex's #1 fan!!
the_man is offline   Reply With Quote
Old 11-19-2010, 07:10 AM   #8
meh, just rub some spf 50 on it, it will be good...
Old 11-19-2010, 08:51 AM   #9
Plumb or Die!
Always ends up being a 2 man job. One pulls the pipe while the other rolls the whole coil and spools it out slowly. Sucks.
plumber666 is offline   Reply With Quote
Circuit stopped working, breaker did not trip nr5667 Electrical 7 07-08-2012 03:31 AM
Recess lighting spot not working bellezza Electrical 4 11-11-2009 07:04 PM
Weather King Furnace Not Working jbickmann HVAC 1 10-22-2009 07:53 PM
Inside Fan not working BenH HVAC 20 07-08-2008 06:10 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
