Worcester 24cdi Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-20-2011, 05:06 PM   #1
Worcester 24cdi boiler
Hi, I've recently moved into a new home to find that the boiler is around 10-15 years old.
The water gets hot but it doesn't get really hot - when trying to run the bath just now the water kept flitting from hot to cold.
So...the pressure needle is just above 1 and the hot water dial is positioned on the third bar.
Should we put the hot water dial to the fourth bar or will that not make any difference??
help!!
pennym24 is offline   Reply With Quote
Old 07-21-2011, 09:48 PM   #2
Just call me Andrew
Rewards Points: 1,020
Is this a boiler with a hot water coil or a standalone water heater? A picture of the unit might help.
Do you have hot water heat in the house?
Andrew
secutanudu is offline   Reply With Quote
Setting the reset "Curve" for a modulating boiler (modcon) mknmike HVAC 5 02-10-2011 12:37 PM
Need help fast please re hydronic boiler water supply and backflow DanDaMan HVAC 6 12-11-2010 03:26 PM
Low water cutoff keeps shutting boiler off dolfish HVAC 7 12-06-2010 05:26 PM
I Need a New Boiler. What do i need to know New Boiler Co Plumbing 0 10-23-2010 07:03 PM
Burnham boiler banging/thumping noises quadradeuce HVAC 6 10-02-2010 10:55 PM
