Worcester 240 Combi Please Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-08-2011, 02:22 PM   #1
worcester 240 combi please help
Hi we just bought a house and the pressure is down on the boiler at 0.
But there is no filling loop it looks like it has been cut off as there is a plastic stop end on one side and then the refill pipe just on another pipe hanging off.
please help any advice would be good
diamond30 is offline   Reply With Quote
Old 03-08-2011, 05:06 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,410
What boiler,..??
Got a Picture,..??
Bondo is online now   Reply With Quote
Old 03-08-2011, 10:32 PM   #3
how
Rewards Points: 1,104
Not enough info. Boiler brand/model/year/picture? Even if your unit has been partially dissassembled you have to have had a water feed line somewhere. By your description it sounds like a totally disconnected boiler but I find that unlikely! The plastic stop could be a hose end that has been put on the drain valve because it was dripping. Is there water inside the tridicator showing "0"(frozen or broken)? Is the unit running? I take it there was no building inspection on this home purchase?
how is offline   Reply With Quote
HELP!! ... Combi boiler. pebo Plumbing 2 12-01-2008 09:31 AM
Filler loop under combi bolier Sheza58 HVAC 2 12-29-2006 06:43 PM
