Wood Fired Boiler - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2011, 11:44 PM   #1
wood fired boiler
What type of circulating pump should I be looking for I want to use 1/2 pex tubing and I am leaving the system open
Willietom is offline   Reply With Quote
Old 11-12-2011, 06:35 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,636
Ayuh,... Mine is runnin' typical Taco, 007 pumps...
Btw,... 1/2" plumbin' is Way to small...
Go with 1"...
Old 11-12-2011, 10:26 PM   #3
Thanks Bondo I playing mad sciencetist here I took a 3 compartment sink and made a fire tube boiler with it heats the water quick and makes steam alot faster then I thought I was thinking that moving the water will stop it from steaming what were you saying run a 1" loop and tap off of it for the rads.
Old 11-13-2011, 07:11 AM   #4
Bondo's Avatar
Ayuh,... There's lotsa ways to do it,...
Mine is a 100 gal. self-built wood boiler that runs constantly through the oil boiler in the house...
The re-light set-point on the oil boiler is lowered, so's it don't light...
The oil boiler is my heat-sink/ distribution point, when the house calls for heat, 1 of it's circulators kicks on, 'n moves the heat to where needed, just as if the oil was heatin' the water...
The DHW is also run through the coil in the oil boiler...
The wood fired outdoor boiler heats up to 'bout 190, 'n the draft closes, shuttin' down the fire, til the water temp drops to 'bout 170, when it re-opens the draft, 'n the fire rekindles..
Of course, My system relies on pressurized water, startin' at 12psi, cold, 'n runnin' up to 'bout 20psi when at it's hottest/ highest...
Old 12-10-2011, 09:26 PM   #5
Wood fired boiler
I built a boiler it sets about 100 ft from my house I ran 1/2 pex lines to and from the boiler to a a/c coil I tried a taco 700 cir. pump it doesn't move the water. any suggestions. I had a pump I got from Harbour Freight on it that moved 25 gals a min. It really worked great but like everything you get at harbour really doesn't hold up
Old 12-10-2011, 09:33 PM   #6
Bondo's Avatar
Ayuh,... Like I said,... 1/2" is Too Small...
Digital Tstat w/ oil fired boiler flatlander745 HVAC 6 01-07-2010 05:59 PM
wood boiler set up sruchar HVAC 2 09-26-2009 05:57 PM
wood boiler set up sruchar General DIY Discussions 2 09-26-2009 06:15 AM
Ext Paint for Interior Application? PaoloM Painting 24 04-21-2009 04:30 AM
DAP caulking question n0c7 Painting 16 10-31-2008 11:31 PM
