Winterizing Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2008, 09:20 PM   #1
Rewards Points: 162
Winterizing issue
Hi,
I attempted to winterize my cabin last week, but was unable to drain down the water heater. I opened the drain valve all the way, but couldn't get as much as a drop out of the thing. It's about 15 years old, so I'm figuring its plugged from sediment. I want to kill the heat to the place because I have no insulation in the walls and very little in the ceiling. Can I leave the water heater full and keep the burner on without causing damage? The rest of the plumbing system is already drained down with RV antifreeze in the traps.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 11-10-2008, 09:36 PM   #2
joed's Avatar
Rewards Points: 12,014
Did you open a tap to let water into the tank at the same time you opened the drain?
Old 11-10-2008, 09:39 PM   #3
biggles's Avatar
put a bucket under the relief and blow off the heaters standing water pressure then open the drain off and take a piece of electrical wire and snake it up the valve...the weight of the water left in the tank might seem like pressure...and you might get a little wet when it starts to drain pull the wire.another trick .......if you still have house cold water run a hose from an outside spiget and fill(quick rush of water) the tank from the drain off whatever is blocking it will blow in the tank.
Old 11-10-2008, 10:29 PM   #4
Rewards Points: 162
I did open both hot and cold water taps after valving off the water at the service - no luck.
I'll try fishing the wire and see if I can pop loose the plugged sediment.
Old 11-10-2008, 11:35 PM   #5
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
If there's a floor drain close by and you dont mind the floor getting a wet you can always remove the drain valve. Of course, that's dicey if you dont want to get wet.
If you do get it drained down I'd replace that drain valve with a nipple, ball valve and a maleXhose adapter. Works well and I've never had one get plugged up with gook.
JDC is offline   Reply With Quote
Old 11-11-2008, 12:15 AM   #6
Rewards Points: 562
I agree with taking off that stupid style of drain,,,real 1/4 turn valve does MUCH better. That will give you MUCH bigger hole to rake an poke thru. Leaving it on all winter is NOT going to work,cause it will dry out and its toast anyway. IF its electric,,you can help by taking out the lower element
4just1don is offline   Reply With Quote
Cable issue or wiring issue? Duchey Electrical 57 12-15-2008 02:34 PM
Fireplace framing/tile issue robdville Building & Construction 13 11-14-2008 08:14 AM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 02:44 PM
Floor Issue... (Concrete) akthomp Flooring 14 09-05-2008 08:57 AM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
