Winterizing A House In New England - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-16-2008, 10:44 AM   #1
Winterizing a house in New England
I know shutting off the main water valve in the house , draining the water lines, water heater, blowing them out with presurized air and putting glycol in the toilets and traps is a must. I wonder if it is necessary to have the city shut off the water in the street. Also I have a hydronic heating system. I assume if I shut it off I need to drain it down and blow it out but if I leave it on at 55 degrees should I put glycol in the system and if so how much dilution. Am I forgetting anything else? Any help would be appreciated.
almostdone is offline   Reply With Quote
Old 10-16-2008, 10:52 AM   #2
joed's Avatar
Rewards Points: 13,316
If you leave it on at 55 you don't need to drain anything. If you are turning the heat completely off then you need to drain the heating system as well.
I would also be concerned about the water line where it comes into the house. The short section before the shut off will still have water and pressure and could freeze and burst. I don't how you would drain that even with it shut off at the street. At least if it froze and broke you would not have a flood with the street shut off.
Old 10-17-2008, 02:19 PM   #3
DIY'r
ScottR's Avatar
joed is absolutely right about the water main where it enters the house and where it goes above the frost line.
Maybe some heat tape? It'll use some electricity, but it's cheaper in the long run than coming back in the spring to a flood..
This site is for manufactured homes, but the article applies equally well to any type of home:
http://www.mygreathome.com/fix-it_guide/heat_tape.htm
(I have no affiliation with the site, but I read over that page and it looks to make sense -- I've also never winterized a house before, so this is just IMO).
ScottR is offline   Reply With Quote
Old 10-17-2008, 02:58 PM   #4
the Musigician
DangerMouse's Avatar
don't forget most public water utilities charge a minimum fee whether water is used or not. 'voice of experience'
just an fyi
DM
Old 10-17-2008, 04:10 PM   #5
don't forget
The wash machine and dishwasher pump need glycol also. I have heard of some people using windshield washer fluid instead. I think it's toxic and not allowed.
The curb stop that the town turns off should bleed off on its own once turned off. What can be a problem , is if there is a back-flow device on the service before the meter, this would prevent the water at the meter from draining out You would have to loosen the union nut on the back flow device if there is one.
Make sure you disconnect any garden hoses and drain the outside faucets.
Last edited by plumcass; 10-17-2008 at 04:17 PM. Reason: spelling --- forgot the hose bibs
plumcass is offline   Reply With Quote
Old 10-17-2008, 08:36 PM   #6
I would not be draining the hydronic heating system. They really shouldn't be messed with unless you know what you are doing.
If you do put in propylene glycol then do it according to the weather in your area. A 50/50 mix will be good for -30 or so. A mix of 20-30% is good for most cases. Just read the recommendations and go from there.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Connecting main house to guest house... hlavine Building & Construction 31 03-28-2012 09:04 AM
replumbing an old house simonfrog Plumbing 7 01-30-2012 04:45 AM
exterior wall shift away from house ldloop Building & Construction 1 01-04-2008 05:12 AM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
help me solve this mystery please lindaberrien Roofing/Siding 17 06-12-2007 01:06 AM
