Winterizing Gas-Fired Instant Water Heating Unit? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2008, 09:34 PM   #1
Long-Time DIYer
Mike Swearingen's Avatar
I'm supposed to winterize a nice home for friends from out-of-state, and it has a propane gas-fired instant water heater in the basement. I've never touched one before, so how do I go about it? I know how to do all but that.
It's over in another county, so I don't know the make yet.
My guess would be to just shut off its ignition breaker, turn off the propane gas, and drain it down with eveything else?
Thanks.
Mike
Mike Swearingen is offline   Reply With Quote
Old 11-20-2008, 10:14 PM   #2
You seem to have it right. There should be some caps on the bottom of the tankless that you can open and get all the water out of the system (after the water is turned off).
When your friend starts up the system in the spring he will get a lot of faults till the pipes get full of water and force the air out. Just let it run and it will eventually start up. He will have to reset the unit several times till it gets going.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-21-2008, 04:41 AM   #3
Long-Time DIYer
Thank you! I will pass your info along to them, too.
Mike
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Solder for hot water heating system junkcollector Plumbing 2 09-12-2008 07:09 PM
Most efficient heating unit farooq Plumbing 1 08-02-2008 05:19 PM
Heating Unit farooq Plumbing 2 07-18-2008 06:23 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
