Wining Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2009, 02:28 PM   #1
Unhappy
Wining Pipes
Hey everyone,
I replaced a kitchen faucet this weekend with success (it functions perfectly). The problem is that ever since the installation my pipes whine incessantly. It abates when any water faucet or appliance draws water, but immediately returns when the flow is stopped. It is very annoying and I had to shut off the water main to get some sleep last night. Any pointers would be most appreciated. Thanks.
Amateur fixer is offline   Reply With Quote
Old 07-15-2009, 05:16 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Wierd noises like that can usually be traced to a failing toilet tank water inlet valve. Turn the water off to your toilet(s) and see if the whining goes away. If it does, replace the valve in the tank with a Fluidmaster 400A for about $5 or $6 bucks. Just follow the easy illustrated instructions that come with it.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
No Cold Water at all - both cold and hot pipes are burning to the touch bluecifer Plumbing 12 01-19-2009 10:29 AM
Frozen Pipes? Plugged pipes? brokenhammer Plumbing 7 01-15-2009 11:10 PM
New Natural Gas pipes being installed frplymstr Plumbing 12 01-05-2009 01:18 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 12:06 PM
