Will This Work? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 04:30 PM   #16
no garbage disposal
Beamsville is offline   Reply With Quote
Old 03-31-2012, 04:59 PM   #17
Rewards Points: 2,516
Heres a few more offset double sink setups
Will this work?-offset.jpg   Will this work?-offset-2.jpg   Will this work?-offset-3.jpg
hammerlane is offline   Reply With Quote
The Following User Says Thank You to hammerlane For This Useful Post:
Beamsville (03-31-2012)
Old 03-31-2012, 06:33 PM   #18
Okay, so I used a new continuous waste setup that was direct connect (The previous one had a double female collar). That raised the trap up a bit. Then I cut off the length of ABS from the old T connection, that way I could use the threads. I threaded on the dishwasher tail piece that I cut off about 2" below the nipple. then put that into a slip adapter, then the trap and it all lined up.
But... What's wrong with the picture? Where's the nipple? It broke off!
so frustrating... Off to the hardware store first thing in the morning!
So hopefully with the nipple on it will still fit, its tight.
Thanks for the help everyone.
Old 03-31-2012, 07:51 PM   #19
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,258
Also that style strainer basket adds an inch or two to the length.
Coastal South Carolina
grounding the workpiece you're welding jarnold Electrical 43 01-03-2016 07:14 PM
Contractor didn't start work in CT - What recourse do I have? ControlTech Off Topic 3 09-28-2010 01:45 AM
HVAC contractor ripoff! sekntonone HVAC 8 04-05-2008 07:15 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
