Will A Newly Sweated Seal Ever Leak..? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2010, 01:49 PM   #1
Will a newly sweated seal ever leak..?
Hello..!
I'm new at DIY plumbing, so appreciate the advice.
I've been making some additions in my home and I've had to learn how to sweat and join water pipes. The first few looked like bird droppings, but as i learned to get the right temp, the sodder just runs right in...
After all the joins are done, one of the hold-your-breath moments is when you turn the water on... So i think i've been lucky and haven't had an immediate leak, but my question is this - if there is no immediate leak, does this mean I have a long term hold..? I'm assuming that with the water pressure if it doesn't leak immediately, it never should... is this correct or am i wishfully dreaming..?
If so, how does one make sure the sodder was 100%?
thanks again
Andy
findlay70 is offline   Reply With Quote
Old 07-06-2010, 03:40 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
Usually, if it doesn't leak when you turn on the normal water pressure, it won't leak. It could last for many, many years if done right, or it could eventually leak if poorly done. Heat the fittings, not the pipe. The biggest mistake that new "solderers" do is to overheat. Don't be afraid to back off with the torch as soon as the solder is pulled into the fitting.
If any of these connections are permanently exposed and accessible, such as under a sink or in a utility room or closet where they will never be enclosed, you can use sharkbites or compression fittings (no soldering).
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 08:39 PM
Shower leak (what else) Old home, new owner... Rubbertree Plumbing 8 09-25-2009 02:26 PM
Toilet Seal Leak Problem boblgamble Plumbing 4 06-21-2008 11:42 AM
Leak in my newly soldered copper piping Mikej-22 Plumbing 7 03-25-2008 10:12 PM
Help with water main seal leak! Taipans Building & Construction 2 03-18-2008 09:06 PM
