Will I Make A Clog Worse By Snaking? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-29-2013, 10:16 AM   #1
Rewards Points: 16
Will I make a clog worse by snaking?
I have a bathroom sink drain that is clogged. It runs down from the second floor to the basement where it ties into the main waste. All other drains in house work fine. I opened the drain near the sink and can run the snake all the way to near the main pipe but it stops. I'm concerned that by snaking it any further it will push the blockage into the main pipe (4" cast iron I think) and clog it. I find ony rust on the end of the snake when I pull it out after sending it as far as I can.
Am I worrying over nothing or can you make the problem worse by pushing a clog farther down a drain? Thanks in advance for any advice offerred!
pennywise is offline   Reply With Quote
Old 05-29-2013, 11:24 AM   #2
Rewards Points: 12,830
How would pushing a clog down a 1-1/2 or 2" line to a bigger 3 or 4" line plug it up?
100% sure the snake when down and not up into the vent line?
Old 05-29-2013, 11:42 AM   #3
Rewards Points: 16
I know the snake didn't go back up the vent because I can hear it rattling in the pipe in the basement. I understand what you are saying about pushing a smaller clog into a bigger pipe but what if the debris is something that doesn't break up well. Any worries about it just sitting in the bigger main pipe obstructing flow and collecting more debris? Since it appears to be rusty debris coming off the end of the snake it doesn't look like it's hair/paper...etc so any concern about this sitting in the larger pipe over time? Thanks for your reply!
Old 05-29-2013, 01:51 PM   #4
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,408
I suppose thoretically, maybe a toy or something that could then lodge accross your main.... but I think the chances are extreemly slight, and what else are you going to do anyway.... and if it did not clear and plugged the main.. at worse you'd have to snake with a cutter the main.
MTN REMODEL LLC is online now   Reply With Quote
Old 05-29-2013, 01:58 PM   #5
Rewards Points: 16
Good point. I guess I have no other choice. I'll continue snaking and hope I can get through it. Thanks.
Old 05-29-2013, 02:01 PM   #6
If you're having trouble snaking, have you tried any chemicals
Old 05-29-2013, 02:20 PM   #7
Roofmaster
Rewards Points: 2,172
Dont use chemicals. Think of a bottle with an open bottom. Your snake is now in the neck, which is a one lane road. Your clog is about to hit the freeway. Snake it, then fill up the tub, then flush every fixture above the clog at close to the same time and sent it packing on the crest of a Tsunami.
The Following User Says Thank You to jagans For This Useful Post:
Javiles (05-29-2013)
Old 05-29-2013, 02:52 PM   #8
Eloquently and poetically stated...
I'd rather snake it too... just sounds like she's having trouble reaching the clog... getting no debris back on end of snake.
Old 05-29-2013, 07:29 PM   #9
Rewards Points: 582
keep snaking....push as you turn ..your at the clog if it won't go easy...ben sr
Old 05-30-2013, 09:44 AM   #10
Rewards Points: 352
Keep cabling, push it all the way to the main. You'll be allright.
plumberinlaw is offline   Reply With Quote
Old 05-30-2013, 10:59 AM   #11
Bill Kearney
Rewards Points: 1,174
Bear in mind if you've got really old plumbing that's rusting out you could end up damaging it. Granted this is usually only an issue at the thin metal of the traps under the sink or in-line from a tub or shower. So don't let your frustration get the better of you when manhandling the snake...
wkearney99 is offline   Reply With Quote
How do you make a shower base for a oversized shower nateyro Kitchen & Bath Remodeling 4 01-17-2012 10:39 PM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 11:48 AM
How to make recessed shelving DesignDuoBlog How To Guides 0 08-30-2011 05:20 PM
Stumped: Basement water and fix- Did I make things worse? jws3 Building & Construction 27 10-16-2008 08:38 AM
Do they make this? Malcolm Roofing/Siding 3 10-14-2007 12:23 AM
