Will I Have Bigger Problems When I Try To Loosen My Galvanized Pipes? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-01-2010, 06:39 PM   #1
Rewards Points: 91
Will I have bigger problems when I try to loosen my galvanized pipes?
Home is 24 years old. Well has some copper, some PVC and some galvanized pipe. I have a leak just past where the pipe comes out of the tank. It seems that a galvanized elbow is leaking THROUGH the pipe wall. I don't see leakage at the joints but it is dripping at the bend in the elbow. Is this possible that the wall of the pipe is corroded through?
Now, when I remove this will I find that the threads are corroded to the point of causing the job to get bigger?
P.S. I just went down and took some pics (aren't those digital cameras something). It looks like just as I suspected, the pipe wall is leaking.
Also, notice the joint where I drew the arrow. It appears that the pipe with the outside threads has been threaded inside to take the short pipe. What kind of problems do you see here?
All recommendations appreciated.
Will I have bigger problems when I try to loosen my galvanized pipes?-dcp_2706.jpg   Will I have bigger problems when I try to loosen my galvanized pipes?-dcp_2711.jpg
sofasurfer is offline   Reply With Quote
Old 08-01-2010, 06:44 PM   #2
Superintendent
Mudpad's Avatar
Is it hard water? Sulfur?
Mudpad is offline   Reply With Quote
Old 08-01-2010, 06:46 PM   #3
Rewards Points: 91
Yes it is somewhat hard since we need have a water softener. As you can see on the valve handle, there is corrosion.
Old 08-01-2010, 06:50 PM   #4
Superintendent
Mudpad's Avatar
Sulfur water is especially corrosive to copper and galvanized pipe. That's why the copper in your picture is turning green and the galvanized is corroded. Best thing to do is replace all that you can with PVC. Or you could replace with Galvanized and it might last another 24 years.
But yes, it looks like you will need to replace most, if not all of what is in your picture.
Old 08-01-2010, 07:01 PM   #5
Owner
LateralConcepts's Avatar
The biggest problems are all the dissimilar metals. Leading to galvanic corrosion and electrolysis. I would replace it all.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following 2 Users Say Thank You to LateralConcepts For This Useful Post:
Mudpad (08-01-2010), oh'mike (08-01-2010)
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 10:03 PM
Replacing pipes in bathroom, need advice Steelmesh Plumbing 7 11-04-2008 12:30 PM
How to diagnose problems with wall kahlan General DIY Discussions 5 10-22-2008 10:18 AM
Elec short causing A/C problems or A/C problems causing elec problems? Marlon Electrical 2 06-25-2008 03:04 PM
Are shower water problems caused by old pipes? bathroom nightmare Plumbing 17 02-02-2008 11:39 PM
