Wierd Problem With Non-draining Bathroom Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-20-2011, 05:21 AM   #1
Wierd problem with non-draining bathroom sink
My bathroom sink won't drain UNLESS I close the drain while I start the water running. When the sink is almost full of water, I open the drain, I hear an air pocket dislodge, and then the sink drains just fine-- quickly, smoothly, no gurgling -- it drains fine AFTER I first close the drain while beginning the water running. Once the sink is draining well, as soon as I stop the water running, the problem reoccurs. So every time I use the sink, I must begin by filling the sink with water, and then opening the drain.
I'm tired of my plug thing coming apart from overuse and then having to fix that too. How can I get my sink to drain without going through this routine?
Thanks for your help.
Wife is offline   Reply With Quote
Old 02-20-2011, 11:28 AM   #2
Rewards Points: 352
First I would pull the plug and cable the line to make sure there was no soap/scum buildup restricting the drain. Then I would make sure the overflow is working and not plugged. Lastly adjust the stopper to open to the maximum height while still being able to seal the sink.
plumberinlaw is offline   Reply With Quote
Old 02-20-2011, 11:38 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,414
Another trick you can try is to use a bottle brush if you can find a small 1/2" diameter one at HDepot etc and poke it up/down thru the drain and under the stopper on a regular basis whilst running the cold water. Then fill the sink fully with cold water and quickly open the drain. THe velocity of the water helps flush the drain and scum you loosened down. I have to do this every month or so as soap scum/hair gel sticks to the stopper body. Easier than snaking it or running "draino" or "liquid plumber" drain solution down and more environmentally friendly. You may want to try some liquid drain cleaner also. Read the instructions carefully and wear rubber gloves.
Old 02-26-2011, 07:25 PM   #4
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
On a bathroom sink it isn't that hard to pull the p-trap especially if it is pvc. What I do is pull the stopper arm out and then pull the p-trap. I tak a paper towel and ush it down the drain to clean all the build up out. Then another paper towel using a screw driver to push it all the way through the p-trap. I then put it all back together, fill the sink all the way up with cold water making sure the stopper holds. Then I open the stopper and look under the sink and use a piece of toilet paper and check for any leaks. I do that about every 6 months or so or whenever it starts draining slow again.
danrb007 is offline   Reply With Quote
Tags
air , bathroom sink won't drain , pocket
Venting a sink pump WillK Plumbing 2 12-26-2010 02:21 PM
slow draining bathroom sink brandonriffel Plumbing 6 06-17-2010 02:20 PM
Reversing P-trap in bathroom sink drain? DK75 Plumbing 3 03-02-2010 02:30 PM
Venting Bathroom Sink chb119 Plumbing 1 05-25-2009 08:22 AM
bathroom sink pressure issue. tgamblin Plumbing 4 04-27-2009 01:21 PM
