Wider Tub For Remodel - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-28-2006, 01:23 PM   #1
Wider tub for remodel
I am putting in a new tub and have already bought the desired tub, but discovered that the drain is 2 inches further from the wall than the original tub (move to right in picture). As you can see in the picture I will have to cut out a section of the joist and add a joist support to make room for the new drain.
My question, however, is what to do with the water supply lines. Can those be diverted without an extensive plumbing alteration and still be under code? Do they have to run vertical until the split?
Thanks for any feedback!
cityman is offline   Reply With Quote
Old 10-28-2006, 01:32 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Yes you can, they can run anyway fit to make the connections.
Ron The Plumber is offline   Reply With Quote
Old 10-29-2006, 11:24 AM   #3
I blame ProWallGuy
Rewards Points: 150
Don't just go cutting that joist any ol way you think you need to. Get a compenent framing carpenter in there to take a look at what you have first and make the changes.
That joist supports the floor the tub sits on. You're adding a larger tub, with more capacity. Water weighs about 8.33 lbs/gallon. That means more load on that joist than before.
Double A is offline   Reply With Quote
Old 10-29-2006, 11:26 AM   #4
Journeyman Plumber
In reality you don't have to cut that joist at all, just off set the overflow on a 45 to bring it back to the same side the original one sits on. Of coure you will need to use a lift and turn or a tip-toe waste and overflow assembly for it to work.
