Why Won't My Hot Water Heater Refill? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-20-2013, 10:27 PM   #1
Why won't my hot water heater refill?
I drained it (to remove sediment) and replaced a faulty relief valve but it's been almost 4 hours and my tank hasn't refilled. I suspect my compensation tank also needs replacing. Would that cause an air lock preventing refill even with open hot taps?
Any advice greatly appreciated.
Claressa is offline   Reply With Quote
Old 04-20-2013, 10:33 PM   #2
Rewards Points: 2,040
Did you remember to turn on the cold water valve above the tank?
Ghostmaker is online now   Reply With Quote
Old 04-20-2013, 10:35 PM   #3
Yup, and ran a load of cold laundry so I know there are no clogs there.
Old 04-20-2013, 10:52 PM   #4
If the valve you shut off is a gate valve it is possible that it broke and remains shut even though you opened it, You will need to replace it with a full port ball valve. Turn the house water off when you do.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
JERRYMAC (04-21-2013), oh'mike (04-21-2013)
Old 04-20-2013, 10:52 PM   #5
Rewards Points: 1,538
I hope to God you did not turn on the gas burner or the electric elements. Turning it on will cause untold damage if the tank is not full. To be sure the tank is full, a hot water faucet upstairs should be gushing.
If you opened the tank drain valve again (use a bucket or hose to prevent spilling water on the floor), does new cold water enter the tank?
The Following User Says Thank You to AllanJ For This Useful Post:
Old 04-20-2013, 10:57 PM   #6
I think it is a gate valve. What an interesting time for it to break. I heard water trickling into the tank when I first opened it back up and there's water rushing at pretty heavy pressure from the drain at the bottom when I open it. Would it break part way open?
The heat isn't on yet. I was waiting for the tank to fill.
Old 04-21-2013, 09:01 AM   #7
Rewards Points: 320
Please post a couple pics of your hwh and the valve your are not sure of when you get a chance - will let you know what type of valve it is. Thanks.
jmon is offline   Reply With Quote
Old 04-21-2013, 09:07 AM   #8
Rewards Points: 320
check out links. It will look something like one of these.
gate valve
ball valve
Old 04-21-2013, 09:33 AM   #9
Rewards Points: 14,010
Should be checking for water flow at a hot water side of a faucet, not the bottom of the tank.
There was no reason to completly drain the whole tank just to get some sediment out.
Make sure to now remove all the aerators and the show head or there's going to be lots of trash in the screens.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
JERRYMAC (04-21-2013), jmon (04-21-2013)
Old 04-22-2013, 09:01 AM   #10
Household Handyman
Rewards Points: 1,408
@ "joecaption": I beg to differ with you Sir. I clean out quite a few water heaters due to sediment build-up as lime is prevalent in my area. I, maybe it's just me, always drain the tank as much as possible, then I use my shop vac with a home-made tool on the end which allows me to reach into all of the bottom of the tank. I try to get all of the build-up out. IMO-leaving any sediment in the bottom of the tank will only allow this sediment to swirl all around when the water enters the tank on fill-up. This may, note: may, cause this sediment to become trapped on the element(s) and as soon as they are heated this will become a hardened surface which restricts heat transfer.
The Following User Says Thank You to Thurman For This Useful Post:
jagans (04-22-2013)
Old 04-22-2013, 09:16 AM   #11
Roofmaster
Rewards Points: 2,210
Did you open a nearby hot water valve in a laundry tub to allow the air in the tank to escape while you were filling the tank with water? Sorry if this sounds like a dumb question, bit there have been a lot of HUH? answers to this type of question on these forums.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
no water at sink after water heater removal rebelbull Plumbing 2 07-19-2011 12:37 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
