-   -   Why won't a big plumber's snake work? (http://www.diychatroom.com/f7/why-wont-big-plumbers-snake-work-182954/)
hoppyhere 07-02-2013 06:41 PM
We just moved into a 1965 house that has sat vacant for 2 years. After being there a week, the toilet started backing up into the tub. We have already tried the typical stuff; plunger, small store bought snake and what not. Now we have removed the toilet and rented a big 100 foot snake. The snake goes in about 2-3 feet and stops. The plumbing pipes are all copper, including the big toilet drain pipe. We have crawled under the house to check out the lines. The lines appear to be straight after the initial first bend. We have worked the snake pretty viciously at the point where it stops and it won't go any further. Does anyone know what could be causing such a blockage? The backed up water will eventually drain, but it takes forever. I'm just looking for any other options before we call the pros, which I'm sure will be costly. From other information I have read, it sounds like we should definately have a camera run down the pipes. Is there anything else we could try? Plus we can't find a clearout anywhere. HELP!!
gregzoll 07-02-2013 06:47 PM
Because you do not know how to use it. You need to hire a real plumber if there is a bad leak. Plus the motorized augers can maim or even kill the person using them if they do not know what they are doing.
If it was a foreclosure, it is possible that the previous homeowner could have poured concrete mix down the pipes also.
sublime2 07-02-2013 06:50 PM
My thoughts, exactly!
hoppyhere 07-02-2013 07:31 PM
There is no leak. It is just seems to be mostly blocked or clogged. Cement down the drain?? People do that? What jerks!!
We have had 2 different people work with the snake. One of them has had plenty of experience with using such pieces of machinery. I myself, would not touch the thing because you are right, I don't know how to use it correctly and would probably hurt myself.
davidblackwoods 07-02-2013 07:37 PM
Well, it's not a mystery
Go to the basement
Cut the pipe section open where it's stopping
Inspect the cut section to find why it's blocked
Replace the cut section after finding said blockage
There is a reason Plumbing is a Skilled Trade
Why we can charge $100.00 an hour for the work
hoppyhere 07-02-2013 07:49 PM
There is no basement, just the crawl space. I'm sure your suggestion would work from the crawl space just the same. Niether of us have any experience with cutting pipes or replacing the cut sections. With all the pipes being copper, what is the best type of pipe to use for the replacement piece? And what other type of tools and/or equipment would we need to buy to tackle this ourselves? We should probably just take it up the drain pipe and pay for a plumber.
I totally understand that plumbing is a skilled trade. I am thankful that those of you skilled in that trade are sharing your thoughts and ideas about my issue. I too am trained in a skilled trade, it's just not plumbing.
gregzoll 07-02-2013 07:58 PM
You would be surprised what people do to places that they live in, before they leave during a foreclosure. Some are decent and just pack up and leave, others make the place so bad, that it may as well be torn down with a shovel and track hoe and a new structure put in its place.
The ground the structure sits on is worth more than the structures nine times out of ten.
Javiles 07-02-2013 08:08 PM
call a professional plumber within an hour you'll know how bad your problem is just dont call roto rooter because if you dont have a serious problem you will after they leave.
oh'mike 07-02-2013 11:32 PM
Copper can be cut and replaced with PVC --the attachment made with rubber Fernco fittings.
Cut out a section of pipe--add a Y fitting with a screw in cap --use this as a clean out.
The snake often chews up the threaded plastic--so do your rodding before you glue in the threaded fitting--
davidblackwoods 07-02-2013 11:55 PM
Listen. Put the snake in again
Jog the forward and reverse. This will flick and flop the tip. Push at the same time.
Please do call a plumber. It will save you so much in the way of headaches
davidblackwoods 07-03-2013 09:35 AM
And I have given answers to every question.
Correct I might add.
Plumbing is very stressful for people
It is one of the most difficult problems in the home to fix.
All the answers I give are from years and years of service experience. Do say that I am sarcastic might be true but I do follow up with the right answer. I won't post something that is not true.
I'm sorry if I've offended you but lighten up.
Atleast I'm helping out. Most pros can't bother with helping a homeowner. and my humour may not be welcomed but my answers should.
I am a ticketed plumber and I have helped users here with there problems researching there problems for them.
All that I do on my own time.
davidblackwoods 07-03-2013 09:41 AM
If I have offended any Home Owner I will post to the straight and narrow.
gregzoll 07-03-2013 01:16 PM
jproffer, there are just some things you leave to the pros to handle.
What you have basically stated is that tere is no longer a need for professionals, so all of those in the trades no longer need to wake up to go to jobs, since homeowners are best to do everything the trades do now.
This is why we are in the mess we are now, that those in the trades cannot find work, because every Joe & Suzi homemaker wants to do stuff that you have to be licensed to do in the first place.
There are just times when the job is beyond a person's ability and this is one of them that they need to call in a licensed pro that can knock it out in less time then they have spent with it already.
TheEplumber 07-03-2013 01:26 PM
199 Attachment(s)
Thread has been cleaned up guys. No more OK? :thumbsup:
Remember--
Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned.
jproffer 07-03-2013 01:32 PM
Nevermind
