Why Use Brass Nipple For Tub Diverter Stubout? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2011, 06:17 PM   #1
Rewards Points: 1,062
Question
why use brass nipple for tub diverter stubout?
i was wondering why it is recommended to use a brass nipple for a tub diverter stubout, which goes out of a dropped L, which costs something like $9 at my HD for 3" length, vs just a regular galvanized nipple for maybe $1.50. there should be a reason, no?
Old 12-20-2011, 06:34 PM   #2
Rewards Points: 13,750
Galvinized will rust and will get smaller on the inside over the years from rust build up.
Brass will not.
amakarevic (12-20-2011)
Old 12-20-2011, 06:49 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Technically true but none-the-less a crock of crap.
Use a galvanized nipple, save the money for something more important and be done with it.
XXX
Old 12-20-2011, 08:02 PM   #4
Military Mom of 4
Snav's Avatar
I was curious - I searched around and found this archived thread:
http://www.terrylove.com/forums/arch...p/t-40808.html
We moved into new construction about 8 months ago and we've been remodeling our bathroom...
At first, we rarely used the tub but did notice that for the first second or two (at most), it would run rusty (hot or cold). The builder told us that it was due to lack of use and would go away in time. So here we are 8 months later and it is still occurring, even with everyday use. If we go longer that 18 hours without turning on the water (hot or cold), it runs rusty for the first second or two.
So here's the deal: We've replaced the original faucet with a Moen Method, same problem occurred. After evaluation by builder, said to replace the fixture (that would make it a third replacement since the original). So we did, still same problem. Yesterday they replaced the entire rough-in...still same problem. I've had 3 plumbers at my house scratching their heads, with no clue on what to do next. The line is plastic (pex?) and brass...No galvanized steel anywhere.
I've read in palces that it's possible that a screw got into the line somewhere, but logic tells me that somehow the water that is left in the fixture once turned off is what's rusting...now what could cause that? Everything in that area has been replaced, including the spout - several times. Everything is new. The fact that it's both lines, tells me the odds of a screw at the right place on both sides, is pretty close to impossible. But to test that anyways we removed the lines from the fixture, waited 24 hours and then ran them straight --they ran clear! So somewhere, somehow rust is getting into the mix in a place that is all plastic and brass.
Any ideas? Suggestions? on what can be causing this?
Sounds to me like at some point someone's going to have to put up with it - and I wouldn't want it to be me but it's not like it's the end of the world.
I bet you that guy wished he was told to just swap out the nipple for a new one when he first bought the house.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-20-2011, 08:14 PM   #5
Rewards Points: 582
no question about it ....galvanized will rust and corrode....brass is the better bet....
Old 12-20-2011, 08:31 PM   #6
Also the drop ell will be brass and the control valve for the shower will be brass so a stell fitting will corrode faster and at some point will make the area where the threads are thinner and may wring off if someone trys to remove the faucet part later on.
Old 12-20-2011, 09:00 PM   #7
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
A brass 1/2 by 3" brass nipple at Home Depot cost $5.70.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Spend the money, it is worth it
Coastal South Carolina
Old 12-20-2011, 11:06 PM   #8
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
so use a piece of 1/2" copper and a couple of male adaptors
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
oh'mike (12-21-2011)
Old 12-21-2011, 06:47 AM   #9
DIY staff
Rewards Points: 7,174
There you go---I've never needed a brass nipple --ever.
Old 12-21-2011, 06:49 AM   #10
Rewards Points: 582
remember what the question was......galvanized or brass......agree copper with male adapters are fine...thats not the question...keep on track
The Following 2 Users Say Thank You to ben's plumbing For This Useful Post:
oh'mike (12-21-2011), plummen (12-21-2011)
Old 12-21-2011, 07:06 AM   #11
DIY staff
So true--easy to get distracted----Brass is nice---galvanized will also work just fine--
Old 12-21-2011, 09:16 AM   #12
Rewards Points: 190
Two thoughts.
A while ago I was doing a project and I bought a 3/4" 2" long brass nipple at the local plumbing supply house for $2.50. A day or two later I was in HD and I noticed the same nipple for $7.50. It seems HD is very competitive on high volume popular items but they make up for it by jacking up the markup on oddball items where people don't keep track of the pricing. The local supply houses are not as marketing savvy and they apply the same markup across the board.
You should not mix two different metals, brass and galvanized in contact in the same run. With the water, it sets up a battery and the corrosion on the galvanized is much worse than if the line was all galvanized. As another poster said, after a while if you try to unscrew the galvanized nipple from the brass, the nipple could break off with the threads of the nipple left in the brass.
zircon is offline   Reply With Quote
Old 12-21-2011, 09:44 AM   #13
Military Mom of 4
Snav's Avatar
Yeah - I'm wary of them at all times and take careful note of costs. . . one time I had to buy a hole-saw for ceramic tile (not cheap) and in one section of the store it was priced for $40.00 and the in the other it was around $32.00 . . . complain I did indeed.
Old 01-02-2016, 03:21 PM   #14
Rewards Points: 2
Same Problem Here - Resolved with Brass Nipple
Hi - I had the same problem after a bathroom remodel where the installer used a galvanized nipple on the tub spout. Less than a year after the installation, the water started running rusty from the tub spout for a few seconds before running clear. I spent 2 years troubleshooting the problem myself before calling a professional plumber. The plumber showed me where the galvanized nipple was rusting. He replaced the galvanized nipple with a brass nipple and it permanently fixed the problem.
I am posting this in case someone has the same problem and save them a call to a plumber to fix something that is easy to fix if you know where to look.
jjgigem is offline   Reply With Quote
The Following 2 Users Say Thank You to jjgigem For This Useful Post:
Ghostmaker (01-02-2016), oh'mike (01-02-2016)
Tags
tub spout
brass end cap on brass nipple leaking bjr72 General DIY Discussions 19 11-05-2011 07:10 AM
leaky new brass fittings at hot water heater dsoelter Plumbing 4 09-10-2010 03:28 PM
Brass Nipple Installation firefish317 Plumbing 2 04-18-2010 03:14 PM
Slip-on diverter with less than an inch of 1/2" copper nipple out of the wall jamesm113 Plumbing 3 07-24-2009 11:23 AM
How tight can a brass nipple be installed? darsunt Plumbing 6 12-20-2008 09:09 PM
