Why Is There A Huge Hole In My Tub? Pics Included - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-18-2011, 01:10 AM   #1
Rewards Points: 81
Why is there a huge hole in my tub? pics included
Why is there a huge hole around the spout input? Is there anything I can do to seal it up other than silicone around the outside?
I just wanted to check the seals around the pipes and tile and found the large hole.
Total Tool is offline   Reply With Quote
Old 12-18-2011, 06:01 AM   #2
DIY staff
Rewards Points: 7,174
What large hole exactly?
Old 12-18-2011, 08:45 AM   #3
Thread killer
Rewards Points: 272
I see holes that will be covered up, nothing out of the ordinary though
Canucker is offline   Reply With Quote
Old 12-18-2011, 09:38 AM   #4
Rewards Points: 3,130
There should be a large, probably round, plate (called an escutscheon) as part of the faucet. It will cover that hole.
Old 12-18-2011, 10:14 AM   #5
Rewards Points: 81
Oh, Ok. So that large of a hole is normal around the faucet area? I figured that it would be the size of the others and be just big enough for a pipe to go through.
There was a gasket on the back of the plate but it didnt do anything since it was smaller than the hole and we would get drips in the basement when using the shower.
Would it be best to just put the cover back on and caulk around it?
Old 12-18-2011, 10:18 AM   #6
Experienced
Jackofall1's Avatar
Looking at that, I would say someone, the tile installer butchered that openning. The hole didn't need to be that big, the hole only needs to be large enough for the valve assembly, and looking at that it should have been half that size.
But you have what you have, so you either have to seal the crap out of the cover plate (which will eventually leak again) or redo the tile.
Mark
Old 12-18-2011, 10:46 AM   #7
Military Mom of 4
Snav's Avatar
He had to gain access to the nuts with enough room to manipulate them.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 12-18-2011, 03:34 PM   #8
So many things I want to say here, but i just won't.
oldhouseguy is offline   Reply With Quote
Old 12-18-2011, 03:36 PM   #9
Military Mom of 4
Snav's Avatar
Indeed!
Unless it's an outside wall - but it doesn't look like it.
Old 12-19-2011, 08:40 AM   #10
Thread killer
Rewards Points: 272
What part of the forum do I go to for repairing a laptop covered in coffee?
Old 12-19-2011, 10:19 AM   #11
Doing it myself
Alan's Avatar
Rewards Points: 2,086
That hole is a little big. Usually it should be a 4" diameter, but it looks like the previous cover plate was covering well enough unless of course you see water damage behind the tile, then maybe it isn't. If it's not, the only thing you can do is replace the tiles surrounding the valve if you can find the same ones.
Journeyman Plumber
Old 12-19-2011, 10:43 AM   #12
It seems to me that those are just white ceramic field tiles. I think you would probably have to take out the entire two rows in order to put in a new backer board substrate to put the tiles on.
I don't think there is enough material for the tiles to adhere to if you just put in four new ones. I would feel better putting in two new rows.
But, hey... I am not a professional tile guy, maybe it would work.
Old 12-19-2011, 11:13 AM   #13
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Maybe that's not the original valve.
XXX
Old 12-20-2011, 10:54 PM   #14
Rewards Points: 81
I thought about that.... The house is 40 years old but I have some found some things that look to be original but also look like a lazy DIY job.
I ended up buying a new spout, overflow and handle/plate. and caulking everything. The overflow gasket was shot and while looking at that I discovered a few places where water was getting behind the wall, so without a major remodel, this was my best option. So far, so good.
Thanks for all the help. This forum is great.
Old 12-20-2011, 10:56 PM   #15
Rewards Points: 81
Indeed!
It's an inside wall. Just drywall behind it
New SOD going brown? Pics Included. the punisher Landscaping & Lawn Care 18 07-04-2011 01:36 PM
Can I cover this hole with insulation? [pics] Brandon19 HVAC 5 10-08-2009 10:47 PM
blower fan not coming on (pics included) TitanTn HVAC 6 02-16-2009 09:48 PM
Need suggestions for Painting my game room... PICS included. jaysen Interior Decorating 8 11-13-2008 11:45 AM
