Why Is The Pipe For Tub Spout Supposed To Be Copper? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 08:31 PM   #16
Rewards Points: 150
Originally Posted by ben's plumbing View Post
no no no don't use pex....copper... if you cant solder ,,,use brass threaded nipples with 90 degree elbow...ben sr
I finished it today. I was just curious.
Arsinek is offline   Reply With Quote
The Following User Says Thank You to Arsinek For This Useful Post:
ben's plumbing (04-27-2013)
Old 04-27-2013, 08:32 PM   #17
Plumber
TheEplumber's Avatar
Rewards Points: 904
Originally Posted by Arsinek View Post
In the instruction to my new shower valve it says to only use copper pipe for the tub spout, what is the reasoning behind this? Im trying to avoid having to have anything sweated, is there a way around this?
You can get valves for iron pipe, copper or pex. But usually only the iron pipe style is available at the box stores. They are more universal for homeowners.
If you buy a tub/shower valve configured for pex- only the H&C supply ports will accept pex. The outlets to the tub and shower will be sweat connections. This is because the manufacturer does not want pex ran to the tub and shower. The reason why has already been stated- it constricts the flow and is not rigid. It is acceptable by some plumbers to run pex to the shower head though.
You can also use brass or galvanized pipe to the tub spout, but then you'll probably need a different tub spout when it comes to trim out time because the one you have is probably for copper
The Following User Says Thank You to TheEplumber For This Useful Post:
Old 04-27-2013, 08:33 PM   #18
Plumber & Gasfitter
Rewards Points: 77
Originally Posted by best handyman View Post
When you solder copper it will be hard and hold the tub spout in place. Pex pipe will move around and the tub spout will move around. Has nothing to do with flow
It has nothing to do with the pipe moving around as both tub spout and shower are installed using drop-ear 90's which are screwed to the wall for support. It has everything to do with flow, it's called the "stacking" effect. Using pex and pex fitting for the tub spout you open yourself up to a situation where the flow exiting the diverter valve is greater then the flow able to exit through the tub spout. Thus the water "stacks" and rises up and out the shower head.
If you are uncomfortable with soldering, just use copper and sharkbites.
joeplumber85 is offline   Reply With Quote
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 07:48 AM
Bent soft copper pipe slkarns Plumbing 3 05-04-2012 11:00 PM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
