Why Is The Pipe For Tub Spout Supposed To Be Copper? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 10:34 AM   #1
Rewards Points: 150
Why is the pipe for tub spout supposed to be copper?
In the instruction to my new shower valve it says to only use copper pipe for the tub spout, what is the reasoning behind this? Im trying to avoid having to have anything sweated, is there a way around this?
Arsinek is offline   Reply With Quote
Old 04-27-2013, 10:39 AM   #2
Thread killer
Rewards Points: 272
Copper doesn't expand as much as the plastics when it gets warm and stays solid. It'll be flopping around if you don't use copper for that particular part.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
Old 04-27-2013, 10:47 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No.
If the tub spout has pex used, the flow rate is restricted in such a way that the showerhead will also run when you only intend to have the tub spout running.
Journeyman Plumber
The Following 3 Users Say Thank You to Alan For This Useful Post:
ben's plumbing (04-27-2013), Canucker (04-27-2013), oh'mike (04-27-2013)
Old 04-27-2013, 10:55 AM   #4
Civil Engineer
Rewards Points: 4,860
I believe Alan is correct. The instructions on my Kohler water temperature controller said exactly the same thing, and explained that the inside diameter of PEX was too small, would restrict flow, and would result in improper operation of the temperature control.
Daniel Holzman is online now   Reply With Quote
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 04-27-2013, 10:56 AM   #5
Rewards Points: 150
Originally Posted by Alan View Post
No.
Thats what I thought it had to do with but wasnt sure. So its because the inside diameter of other pipes is smaller and causes water to flow up the shower?
Can I use cpvc?
Old 04-27-2013, 11:10 AM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,228
Don't use CPVC but you could use a threaded brass nipple.
Coastal South Carolina
Old 04-27-2013, 11:23 AM   #7
Thread killer
Rewards Points: 272
No.
Even if you've run pex to a drop ear overhead?
Old 04-27-2013, 11:27 AM   #8
A "Handy Husband"
rjniles's Avatar
Don't use PEX for the run up to the shower or down to the spout. Copper is the best choice. The PEX is to restrictive for either location.
Old 04-27-2013, 11:53 AM   #9
Rewards Points: 150
Im thinking about doing the tub spout with copper using shark bites and one compression fitting.
Old 04-27-2013, 12:04 PM   #10
JOATMON
ddawg16's Avatar
Rewards Points: 1,976
I used stainless steel.....
ddawg16 is online now   Reply With Quote
Old 04-27-2013, 03:28 PM   #11
Lord of Slums
Rewards Points: 1,974
I have done over a dozen shower/ tub set ups using only pex and have never had a problem. In other people's houses I would only use copper because it is the best way to go.
mj12 is offline   Reply With Quote
Old 04-27-2013, 03:34 PM   #12
Rewards Points: 6,652
Just go from 3/4 to 1/2" reducer at the shower & tub faucet.
Old 04-27-2013, 04:11 PM   #13
When you solder copper it will be hard and hold the tub spout in place. Pex pipe will move around and the tub spout will move around. Has nothing to do with flow
best handyman is offline   Reply With Quote
Old 04-27-2013, 08:13 PM   #14
Rewards Points: 150
So youre saying if you secure PEX it would be ok?
Old 04-27-2013, 08:29 PM   #15
Rewards Points: 582
no no no don't use pex....copper... if you cant solder ,,,use brass threaded nipples with 90 degree elbow...ben sr
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 07:48 AM
Bent soft copper pipe slkarns Plumbing 3 05-04-2012 11:00 PM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 08:22 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 08:44 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 07:48 AM
