Why Are PEX Crimping Tools So Damn Expensive? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-04-2011, 04:56 PM   #1
Why are PEX Crimping Tools So Damn Expensive?
My God. I don't want to buy the factory that built the crimping tool, just the tool?
Am I being unreasonable here? Is this some sort of monetary barrier put up by the industry to discourage DIY'ers from going PEX?
FirstAndTen is offline   Reply With Quote
Old 02-04-2011, 05:02 PM   #2
That's a few hours labor cost for never hiring a plumber again!!! Lol it's well worth it
Alcarte is offline   Reply With Quote
Old 02-04-2011, 05:12 PM   #3
Supply and demand.
broox is offline   Reply With Quote
Old 02-04-2011, 05:35 PM   #4
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Yeah I always wondered this too. It's not really a complex tool, and I'm sure it cost about $5 to make considering it's probably made in China by kids being paid 3c per hour.
I'm sure someone who is decent at machining could make one for a fraction of the price if given the proper dimensions.
Old 02-04-2011, 06:38 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 566
They got you where they want you. An easy to use system, but you need a specialty tool.
Kind of like buying those specially priced printers. Real neat until you drop $30.00 for a new ink cartridge
Old 02-04-2011, 07:21 PM   #6
Rewards Points: 268
Capitalism. They can charge what they want. No reason for them to lower the price, as long as they're selling
packer_rich is offline   Reply With Quote
Old 02-04-2011, 07:23 PM   #7
Check a local pawnshop they should have one for a lot less
Old 02-04-2011, 07:53 PM   #8
Rewards Points: 16
If you think the crimping tools are expensive, you better not look at the expander tool.
HairClog is offline   Reply With Quote
Old 02-04-2011, 07:58 PM   #9
Seasoned DIYer
Rewards Points: 150
Sports equipment, apparels, watches, consumer electronics and all sorts of other things have so called "MAPP", a vertical price fixing imposed by manufacturer to protect the value of the brand. Basically retailers can't advertise the products below the minimum advertised price policy set point.
Perhaps tool manufacturers do the same. This isn't anything about protecting the trade. It's common among many products.
Also, if the tool uses something that is patented, the patent holder can withhold anyone else from making it or allow someone to make them, but licensing must be paid which raises the cost.
Good tools are usually expensive and not every tool is available at Harbor Freight.
If the tools are patented, that is actually illegal. The shop is subject to civil litigation by the patent holder.
HVAC_NW is offline   Reply With Quote
Old 02-04-2011, 08:02 PM   #10
couldn't have said it better myself
the_man is offline   Reply With Quote
Old 02-04-2011, 08:07 PM   #11
Wire Chewer
Rewards Points: 90
Yeah forgot about that... another broken legal system. imo anyone should have the right to make what they want, how they want. Patents, copyright and all that junk simply hinder fair competition and creativity... but that's a whole other debate, let's not go there.
Old 02-04-2011, 08:11 PM   #12
Seasoned DIYer
Rewards Points: 150
I've never done PEX crimping, but from what I understand, they need to be properly calibrated or risk unreliable connection. If you're a DIYer, go rent the tool, or use Sharkbite fittings.
There are certain things you just can't do with cheap tools. You can replace the tie rods on your car, then install brand new tires. Tools to do proper alignment or having it done is too costly. You could skip it and it'll work for the time being, but you'll pay for it later when the tires are bald in 1,500 miles.
You can probably hack crimping to make it work and not leak at the time, but you'll probably pay for it in water damage later on
Tools for a newlywed beginner mephysteaux General DIY Discussions 9 09-24-2010 10:43 PM
Pex Crimping Tools? DeadHead Tools 12 08-30-2010 08:16 PM
What to do with all the shop tools when the shop master passes away ??? JohnFRWhipple General DIY Discussions 8 06-21-2010 07:32 PM
Value of used tools Texasguy Building & Construction 6 06-02-2007 11:03 AM
