Why Isn't A 2-1/2" Nipple 2-1/2" Long? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-09-2013, 01:28 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Why isn't a 2-1/2" nipple 2-1/2" long?
Is this a technical thing or is this a made in China thing? Just want to make sure before I go looking for something that doesn't exist...
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 03-09-2013, 01:36 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 996
I havent had to buy a galvanized nipple in years, you use too get them in closed 1 inch inch and a half and so on up to 12 inches. but 2.5 inches is just that.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-09-2013, 01:57 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Typically, when you talk about nipples.....the 2 1/2" refers to the diameter....you have close nipples...long nipples....big nipples (oooppppssss, sorry, wrong nipple). A close nipple is going to be just long enough to get the proper amount of threads on each end....the larger the diameter, the longer it's going to be.
Old 03-09-2013, 02:17 PM   #4
A 1/2" nipple 2 1/2" long will measure 2 1/2" long including 3/4" thread on each end. So if you measure 2 1/2" between both female fitting you will need a 4" nipple I believe. It has been a long time since cut pipe.
Hardway is offline   Reply With Quote
Old 03-09-2013, 02:40 PM   #5
if you measure between fittings you add 3/8-1/2 for each end. depends on how the dies were adjusted when the threads were cut. some used to thread in 1/2 inch and some were tighter at only 3/8 threaded in. a 2-1/2 inch nipple measures 2-1/2 inches long.
Old 03-09-2013, 03:00 PM   #6
Still going...
ChrisDIY's Avatar
Rewards Points: 508
So if specs call for a 2-1/2" nipple it should be exactly 2-1/2" long? Using 1/2" pipe. Measured, it's 2-3/8"
I got stung by a kohler measurement before so need to know if they may want it exactly 2-1/2"?
--Chris the DIY Guy
Old 03-09-2013, 03:15 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 912
A nipple or pipe is measured end to end. But you field measure for cutting center-center or face-face of fittings and deduct/add the make up or take off of the fittings.
Line up several 1/2 x 2 1/2 nipples and they will vary in length up to a 1/4"
Old 03-09-2013, 03:54 PM   #8
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Changes a lot depending on where you get them from too. We had some that were + 1/4 from one outfit, and some that were - 1/8 from another. Sometimes having different lengths other than the standard 1/2" increments helps a lot when the tile guy bends you over the shower seat.
Journeyman Plumber
Old 09-13-2013, 08:02 AM   #9
Still going...
ChrisDIY's Avatar
Rewards Points: 508
So of course I finally installed the showerhead that used those 2-1/2" nipples that were 2-3/8" low and behold I needed the nipple to be exactly 2-1/2" The 1/8" caused waterway to interfered with escutcheon.
I'm technically done with the plumbing part of our house remodel but I should have bought a hand pipe threader. Kept it or eBay.
--Chris the DIY Guy
The Following User Says Thank You to ChrisDIY For This Useful Post:
oh'mike (09-13-2013)
Maximum wires in a 2 1/2" nipple elmaur Electrical 27 06-12-2012 04:08 PM
radiator union elbow and valve nipple fitting amakarevic Plumbing 1 11-12-2011 02:30 PM
How Long Do We Have? Docfletcher Off Topic 19 05-01-2010 11:02 AM
The long, dark road of renovation. Curb Feeler Introductions 1 02-03-2009 01:47 PM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
