Why Important For Toilet Tank Water Level To Be Certain Distance Below Overflow Tube? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2016, 04:32 PM   #1
Rewards Points: 1,472
Why important for toilet tank water level to be certain distance below overflow tube?
Why is it important for toilet tank water level to be a certain distance (1" maybe) below top of overflow tube?
I remember now that there was also a certain adjustment of the fill valve (top of it maybe) that was spec'd in the instructions.
Thx, Ducky
justplumducky is offline   Reply With Quote
Old 05-10-2016, 05:11 PM   #2
Rewards Points: 198
Re: Why important for toilet tank water level to be certain distance below overflow t
If the level is too low then you will not have a complete flush . If its too high there is a chance the water level over time can creep up over the top of the overflow tube . The mark on the fill valve CL should be at least 1" above the top of the overflow tube .
daveblt is offline   Reply With Quote
The Following User Says Thank You to daveblt For This Useful Post:
justplumducky (05-10-2016)
Weird Water Heater Issue I Bet You've Never Experienced Before hellohello Plumbing 6 01-09-2014 12:40 AM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 06:55 AM
questions about plumbing hot water tank bubbler Plumbing 13 01-18-2012 07:43 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
