Why Doesn't This Exist? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-01-2012, 08:55 AM   #1
Military Mom of 4
Snav's Avatar
Why doesn't this exist?
If it does - let me know - because obviously I'm unaware.
But wouldn't it be snazzy to have a wall/floor/ceiling protector flange that's a tube which slips into your opening before you feed in your new pipe - with one end that springs open like a hollow wall anchor so it's braced but inserted from one side only? Like a gasket or an extended escutcheon that is made to protect the surface of your pass-through.
I've actually always wanted to use something like that so pipe doesn't rub or contact flooring/wallboard/etc - which might also help to protect against leaks that I've had to repair (such as when a pipe passes through 4x4) but they just don't seem to exist.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 01-01-2012, 11:17 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 542
I know these are not what you're looking for but I think its as close as you'll get
http://www.ipscorp.com/watertite/pip...pipeinsulators
Does 1.5" thick drywall really exist? mikheil Drywall & Plaster 19 11-12-2010 06:11 AM
Making a footing for slab that already exist? stewbstew Building & Construction 16 04-09-2009 04:06 PM
Does it exist Rze Electrical 15 10-15-2008 07:31 PM
Does this window exist? ClnlBrahm Building & Construction 4 09-19-2008 04:30 PM
Do these exist? (stone tiles that aren't square) joeyboy Flooring 3 04-11-2007 12:38 PM
