Old 07-12-2010, 04:26 AM   #1
Why does my water heater smells like burnt plastic?
Hi, my water heater has recently, periodically produced a smell of burnt plastic (from the exhaust tube area). I played with the heat temp and the burner turned off. Since then (a week or two ago) I haven't smelled it again...but it concerns me. The water itself doesn't taste or smell funny. Do I need a new water heater?
Player is offline   Reply With Quote
Old 07-12-2010, 07:07 AM   #2
The only thing I know of in a water heater that might smell like plastic is insulation, and that is normally well packed away from the flame. Pull the bottom cover and check the burner area, it may need cleaning. Rust and debris often drops down and can disrupt the flame. If this is a newer gas heater with explosion proof devices, you can't do any maintenance on the burner.
Old 07-12-2010, 01:30 PM   #3
I'll check, but I think it's an older unit. Looks new, but I know it isn't.
water heater drip kdange1 Plumbing 5 05-04-2010 04:24 PM
Tankless Water Heater welshie Plumbing 12 03-03-2010 01:46 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Stumped. Water heater woes. bigcaddy Plumbing 35 06-14-2009 06:12 PM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 11:36 AM
