Why Do Sump Pumps Have 2 Cords? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2009, 09:19 PM   #1
Rewards Points: 184
Why do sump pumps have 2 cords?
On all of the ones i have seen they just plug into each other anyway.
abefroman is offline   Reply With Quote
Old 02-19-2009, 10:15 PM   #2
Normally, one is for the (internal) float and one is for the pump motor operation. While they may be operating from the same outlet, they are controlling two different things. If you just plug in the one that controls the motor, it should run continuously. Many sump pumps have a separate float that is connected outside the pump and "flips" the motor on and off at certain positions or heights.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 06:09 PM
Sump Pump Design handy man88 Plumbing 2 10-04-2008 09:48 PM
Sump Pumps RobertS Plumbing 3 02-22-2008 02:34 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
