Whoops...Broke Line Into Fridge. Now What? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2012, 12:55 AM   #1
Hello,
I was moving the fridge and accidentally broke the connection from the fridge to the water. I have an older home so it appears the piping that brings
the water to the fridge is copper. In the process of moving it I snapped off the part near the fridge where the piping is attached to the nut that
screws onto the fridge part. Hopefully this makes sense.
Anyway, I'm trying to figure out what to do next. Should I solder it...is that the best option? I've heard of stuff called liquid nails. I've also
heard of something called "pex" that is flexible piping. I'm quite handy around the house and do my own repairs on things but this is the first time
I've ever had this happen so I'm open to learning what is the best option.
Jason
Jason001 is offline   Reply With Quote
Old 05-26-2012, 03:48 AM   #2
biggles's Avatar
if the nut is still screwed onto the fridge part(threaded piece the nut goes on) male part? or did the copper pipe snap?
Old 05-26-2012, 05:58 AM   #3
Rewards Points: 1,216
Relax take a deep breath it's a very minor problem give us more info and we will walk you through it. What size copper? Soft or Hard? How much is still behind the refrigerator EX Feet? What's the piece on the refrigerator look like? Is it still there, as asked previously? Holiday weekend answers may be slow coming.
COLDIRON is offline   Reply With Quote
Old 05-26-2012, 07:29 AM   #4
Rewards Points: 93
Relax...as long as the fitting near the wall / shut-off is intact and useable then you can screw on and / or adapt braided stainless steel line from wall to icemaker.
The kits sell at HD and Lowes.
George6488 is offline   Reply With Quote
Old 05-26-2012, 12:35 PM   #5
Homerepairguy's Avatar
Rewards Points: 998
Originally Posted by Jason001 View Post
... heard of something called "pex" that is flexible piping.
Suggest not using PEX for the icemaker supply line. Icemaker supply lines have to be coiled in the back of the refigerator to be able to roll the fridge in/out. This leaves the PEX line exposed. Who hasn't ever had a mouse in the house? Though having one or two in the house is usually rare, the critters like to gnaw on PEX to get at the water. Read flooding.
PEX needs to ALWAYS be protected from sunlight (direct or indirect) and rodents. Suggest using only copper or stainless steel braided line for icemaker supply lines.
HRG
Homerepairguy is offline   Reply With Quote
Main Line Clog Master Brian Plumbing 46 09-06-2012 08:38 PM
Old water supply line a_lost_shadow Plumbing 7 04-19-2012 11:12 PM
Sizing a dual shut off valve for a water line to fridge ericman Plumbing 10 08-19-2011 09:47 PM
Do I need to prime my oil feed line? 1parkpointer HVAC 3 10-22-2009 06:52 PM
Need Advice - How to run Fridge Water Line Joshcube Plumbing 3 03-20-2009 04:56 PM
