Whole House Water Treatment Systems - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-11-2008, 06:42 PM   #16
Originally Posted by Marvin Gardens View Post
I had a small filter on for 4 years and it finally started to slow the flow. I finally figured it wasn't worth the cost and pulled it out.
Yes, I can imagine that after 4 (four!) years your water MIGHT slow down!
Andy CWS is offline   Reply With Quote
Old 05-07-2012, 07:00 AM   #17
Hello,
first of all i sorry to intercept you guys...
New member here and very excited I found this community! Just a general question as I have been doing research here and across the web on the topic of whole house
water filtration systems. I really want to get one to remove the clorine and floride and all the other usual suspects. I was wondering if anyone has any recommendations I should be looking at?
The only one that I have really found is linked below. Thanks for any help!
Big Berkey
David_Brett is offline   Reply With Quote
Old 05-07-2012, 09:41 AM   #18
update
After doing as much research as possible, I finally made a decision and went with the Pelican Water Filtration system. Initial cost was about $2400. But what a difference it made. You could smell the difference in the water. No more dry skin in the shower. Clothes and dishes came out cleaner. Tap water was drinkable.
I ended up selling this house after 2 years, and moved into a rental house with just a salt based softener, and I miss my water filtration system!!
Robert131 is offline   Reply With Quote
Old 05-08-2012, 07:58 AM   #19
Normally in our home the all water management system is connected through the main valve so there may be any leakage in anywhere in the pipe then we need water treatment system for this problem.In this you should hire only professional plumber.
________________________________________________
Best Leak Detection Services
Peterburke43 is offline   Reply With Quote
Old 04-25-2013, 12:17 PM   #20
Always learning...
fetzer85's Avatar
Rewards Points: 262
Wow, I've never seen so many trolls bring a thread back to life so many times. Quite annoying to the many good people who actually use this site.
Post count < 10 + links in posts = RED FLAG
fetzer85 is offline   Reply With Quote
Old 04-25-2013, 03:16 PM   #21
Are talking about yourself?
Old 04-25-2013, 08:53 PM   #22
Always learning...
fetzer85's Avatar
Rewards Points: 262
Lol no, there were 2 posts before mine that were removed, so you're right, now it appears I brought it back.
Lemon of a house my responsability beefy HVAC 7 02-17-2007 07:23 PM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 10:36 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
Noise when turning on water anywhere in the house pkulkarni001 Plumbing 2 04-10-2006 04:20 PM
