Old 06-27-2009, 10:32 AM   #1
Default Whole house water filter question
I installed 2 Culligan water filters (see link) and have a question about the correct filter I should use with these.
Filter -
http://www.waterfilters.net/culligan...ings/HF360.htm
Have a well and have seen sand in my system. Have no problems with smell or bad taste in the water.
Assume pleated for greater filtering??
I have 2 so was thinking of putting a larger one (20 micron) first to catch the sand and a smaller one (10 or 5 micron) 2nd to clean the water.
Does this make sense?
Davidb6 is offline   Reply With Quote
Old 06-27-2009, 02:22 PM   #2
Water quality'n pump guy
Filter -
The naked eye can't see particulates less than 50-45 microns; the lower the number the smaller the particle. So your micron rating is way too low to filter sand and, a disposable cartridge filter is a bad choice for filtering sand. Using just the housing without the cartridge will filter sand.
You are going to install any filter after the pressure tank right? Never anything before the pressure tank.
Have you tried to dissolve some of this sand in vinegar to make sure it is sand and not hardness scale?
Gary Slusser is offline   Reply With Quote
Old 06-29-2009, 10:31 AM   #3
These two are installed right after the pressure tank.
I need to change my first filter now so I'll try to dissolve some of the grit (sand) in vinegar...what will I be looking for?
Old 07-01-2009, 04:54 PM   #4
A coarse pleated filter should remove all the sand. But what exactly are you trying to "clean" out of the water besides the sand?
Old 07-01-2009, 11:36 PM   #5
I think if it dissolves there won't be anything to see.
If it doesn't dissolve, you have sand and if it does, it is hard water scale.
If it doesn't dissolve, the filter housing without a cartridge is sufficient to trap sand.
More On This Topic
Pottery Clay Making Safety
Pottery Clay Making Safety by Expert Village
Before we go any further talking about how to mix a clay to use in pottery, I want to talk about safety as it relates to that process. Now the biggest health hazard in any ceramic studio environment is dust. Clay materials are basically dust. It's... Read More »
Swimming pool filters remove oil, grease and dirt from your pool. They are a fundamental part of most swimming pools' hydraulic systems. Selecting the correct swimming pool filter can make maintenance easier. The correct filter can also make your pool's... Read More »
Jacuzzi Filter Maintenance
Jacuzzi Filter Maintenance by Expert Village
Hi this is Francisco Cales from Tampa, Florida with Pool Inspectors on behalf of Expert Village. Our theme for today is basic spa maintenance. When cleaning your filter, the first thing to check is whether the filter needs cleaned. Find out what the... Read More »
How to Use a Water Filter
How to Use a Water Filter by Expert Village
Hi. I'm Mike Meyers with Zion Wilderness Survival School for Expert Village. And, we're going to talk a little bit about a water filter. You may recall in one of the other episodes, we looked down a hill into some cottonwood trees and we said that's a... Read More »
Hi. My name is Allen for Expert Village. And today I'm going to discuss a controversial and banned alcohol commonly known as absinthe. As they came up with a filtration process that works very much the same way. And it's a carbon micron filter that works... Read More »
How to best filter water for open loop geothermal Jim S. HVAC 5 06-10-2009 07:02 PM
Foamy Hot Water - Question jay9890 HVAC 1 04-20-2009 12:14 PM
Hot water tank drained - now whole house filter clogs easily bgalizio Plumbing 16 04-19-2009 08:46 AM
Whole house water filter location Soloed Plumbing 2 02-04-2008 09:32 AM
Loss of water pressure in my house... stormyjas Plumbing 6 02-15-2007 12:36 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
