Whole House Magnets - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2013, 09:04 AM   #1
Rewards Points: 256
Whole house magnets
My water is extremely hard (42 grains). I have a water softener, however at that hardness a softener can only do so much. In 32 years Iíve gone through four water heaters, three kitchen faucets and two bath tubs. Iíd like to know if anyone has had any experience with whole house magnets. Do they work, or any other suggestions short of moving. Any help is appreciated.
Best of Luck
Steve
spraygunn is offline   Reply With Quote
Old 04-12-2013, 09:26 AM   #2
joed's Avatar
Rewards Points: 12,362
magnet water softeners are a scam.
The Following 4 Users Say Thank You to joed For This Useful Post:
joecaption (04-12-2013), spraygunn (04-12-2013), user1007 (04-12-2013), VIPlumber (04-12-2013)
Old 04-12-2013, 09:57 AM   #3
Too Short? Cut it Again!
Water in my N California home was dreadfully hard and like you I went through water heaters fairly quickly. Faithfully flushing them helped somewhat. I finally switched to tankless back when they were still fairly novel in this country. My logic was the water would not be sitting or pooling in them. The units were Bosch and not cheap. I sold the house within a couple years of putting them in so do not know how it worked out.
It was nice to have hot water on demand where it was needed without wasting lots from the water heater to the baths on opposite ends of the house.
Magnet water conditioners are even more a scam than those sonic insect repellent things.
The Following User Says Thank You to user1007 For This Useful Post:
Old 04-12-2013, 11:17 AM   #4
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
I had the same question when I first got here.
Electronic Water Conditioner?
Old 04-13-2013, 09:42 PM   #5
Rewards Points: 352
Scam. If you want your water heater to last you will have to do a couple of things. 1. Change your anode rod regularly 2. Flush the sediment from your tank four times a year.
plumberinlaw is offline   Reply With Quote
Old 04-14-2013, 05:52 AM   #6
Rewards Points: 3,130
When I was shopping for a tankless to put in the house I was building, I was told that they should not be used if you have hard water. Apparently they fail in a short time.
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 07:18 PM
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 03:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 02:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 10:09 PM
