Who Can Tell Me What Valve It Is? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-16-2009, 02:39 AM   #16
kun
what size it is
the valve or cartridge diameter is 1-3/4 inch, is Premier same? Delta is 2 inch.
kun is offline   Reply With Quote
Old 06-16-2009, 11:14 AM   #17
Rewards Points: 252
do you have the trim?? If yes - did you see any brand identification on the handle or trim plates?? Can you take pics of the trim and post them?? There are soooooo many look alike imports that it is so hard to guess brands without actually seeing a brand name.
If you don't have the trim - It would cost you more in time and materials to buy the trim and the valve - why not just change the shower body??
good luck!!
mazzonetv is offline   Reply With Quote
Old 06-16-2009, 12:27 PM   #18
Man of many hats
wrangler's Avatar
Rewards Points: 354
This particular one is 1 9/16" inside
Man of many hats
wrangler is offline   Reply With Quote
Old 06-17-2009, 02:13 AM   #19
kun
I don't have a trim
sorry no trim, I don't want to tear down whole wall to install a new set, so anybody see this valve before or any advice, very apraiciate. it maybe 1 9/16" inside.
Old 06-18-2009, 03:15 AM   #20
kun
all I found on valve is "ASSE, TYPE P, 1016, up, down, 873", is that a model #?
Old 06-18-2009, 05:44 AM   #21
Man of many hats
wrangler's Avatar
Rewards Points: 354
873 might be the model #. ASSE is the American Society of Safety Engineers and 1016 is the standard for anti-scald control and type P is the specific method of anti-scald. A Google search of that model brings up Pegasus which is sold by Home Depot. Have you taken your cartridge there to try and match it up?
Man of many hats
Old 06-20-2009, 07:59 AM   #22
Replace
Kun, you have asked several questions regarding this plumbing issue why don't you save yourself and us a lot of aggravation and just rip the wall out and install a new complete diverter you will be glad you did I am sure.
Just cut out a square access hole behind it like 18 x 18" get in there do what you have to do and install an access door over the hole in case this happens again.
I know you have to solder and you can't, just find someone to help you.
Install a Delta product they are easy to rebuild if leaks occur down the line.
SULTINI is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Double Check Valve installation (and a few other questions) secutanudu Plumbing 0 04-17-2009 08:42 AM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
