Whistling Water Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2009, 11:48 AM   #1
Rewards Points: 640
Talking
whistling water pipe
My house's water pressure was coming in last week when I checked at 110 psi... thought there was a problem because the Pressure valve on the water heater was leaking and I just replaced it! and it only happened when the heater ran... so I brought the system up to code... it was a cosed system with a one way valve on it, so I put a pressure reducing valve on after that, droped the pressure down to 60 psi and after that put a thermal expansion tank on as an extra precaution since it is a closed system... and we are supose to have them by our code on a closed system.... well after that the toilets ran much quieter when filling, the sink's faucets dont splatter water all over the place, our washing machine is quiet when filling, everything is great! well except one thing, the bathtub shower... when it is running it now makes a very loud whistle noise, nothing else in the house does this! and it did not do this before I droped the pressure down to 60 from 110 psi.... is the valve bad in the shower? if not any idea on how to fix this? thanks!
BlueBSH is offline   Reply With Quote
Old 12-10-2009, 02:37 PM   #2
Rewards Points: 1,452
Probably a pocket of air somewhere in the pipes. I don't know of any way to get rid of that other than perhaps turning the water on high and seeing if the air gets flushed out. Otherwise the air will be gradually absorbed.
AllanJ is online now   Reply With Quote
Old 12-10-2009, 02:52 PM   #3
Rewards Points: 640
I dont think it is that, I flushed and purged the entire system, and after a week not it is still whistleing... could the diverter or something be causing this? it only happens when the shower head is turned on... not when the spout is running... but the shower head is only 4 months old and wasnt doing this until I fixed the water pressure....
Old 12-10-2009, 03:14 PM   #4
Rewards Points: 150
Take the shower head apart and clean the screen. Could be some sediment worked through the pipes.
Does the tub fill also squeek? or just the Shower head?
TJ_in_IL is offline   Reply With Quote
Old 12-10-2009, 03:28 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
It's probably the scald proof feature in the shower control. The balance valve inside it is in a new position due to the reduced pressure and it is chattering. Mine did it until it sort of got broken in. A very quick flip of the temp control usually quieted it...... at least for a while. It has pretty much stopped now that it's been in use for a while.
Old 12-10-2009, 03:32 PM   #6
Rewards Points: 640
just the shower head does
pipe for water main. RonFromSeattle Plumbing 3 06-19-2009 01:04 PM
Loud Hum / Vibration - Water Pipe in Condo michellelukezic Plumbing 4 06-15-2009 07:34 AM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Bubbling in toilet rballard Plumbing 11 08-30-2008 08:15 PM
