Whistling & Rushing Water Noises In Pipes - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2009, 12:45 PM   #1
Question
whistling & rushing water noises in pipes
Hello,
I just bought a triplex (we have tenants upstairs and in the basement, we live on the main floor and also have a basement) the construction is not that old, it was built in 1986. Recently, I have noticed 2 noises coming from the pipes (i assume its the pipes).
1- There is a distinct whistling sound that lasts for a few minutes when we use our shower or flush our toilet on the main floor. The sound goes away when we flush our downstairs toilet or close the downstairs toilet valve. My father in law seems to think we would have to change the valve in the downstairs toilet. The tenant downstairs also hears a sharp whistling sound when she flushes her toilet that lasts a few minutes. The upstairs tenant doesn't have this problem
2- Recently, Ive been hearing a sort of waterfall (rushing water) noise from time to time. I have no idea what that could be.
We're probably going to call a plumber but I just wanted to know what it could be and if it's a serious problem.
Thanks!
nicola777 is offline   Reply With Quote
Old 07-06-2009, 08:50 PM   #2
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Exclamation
Noise in pipes !
It sounds like the fill valve in one or both toilets has gone bad
these are called a ballcock,
when the rubber inside gets wore down they start to make that noise like when you blow across a piece of cellophane,
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
Hot water coming out of all pipes...help! memedrvr2 Plumbing 22 05-12-2009 09:21 AM
Why do i hear the water in my heating pipes? CMG Plumbing 3 12-09-2008 12:33 PM
