Whistle In My Water Softener-What Is It? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-08-2010, 09:50 PM   #1
Rewards Points: 91
Whistle in my water softener-What is it?
I have a whistle coming from my water softener when it is in the recharge cycle. It is just a steady whistle coming from the top electronic portion. Its a Kenmore 80 Plus Super Salt Saver. Quiet a few years old. Not knowing anything about water softeners and having no idea what I am talking about, I would guess that a valve is not open all the way or is plugging up and the water is working harder to get through. I think it whistles on high volume water flow and does not whistle on low volume water flow. I don't know what the different cycles are.
So. is my guesstimate close? What do you think it is and can I fix it?
sofasurfer is offline   Reply With Quote
Old 09-08-2010, 10:38 PM   #2
Water Treatment
Rewards Points: 900
Check to make sure that the drain line does not have any kinks in it from start to finish.
Akpsdvan is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Went to city water - softener still needed? uncleslam General DIY Discussions 5 11-15-2009 04:08 PM
Help with Water Softener TTran Plumbing 5 05-27-2009 06:08 PM
Water Softener wont stop draining help TTran Plumbing 3 08-24-2008 08:16 PM
