Old 08-26-2008, 02:49 PM   #16
whirlpool tub leaks onto bathroom floor
Originally Posted by buletbob View Post
So you are saying that the water appears at the drain end of the tub??? and it does not leak when your not in the tub.when the water reaches the problem height. what kind of base is the tub set on??.
The tub is an oval shape, spa-type with the drain mid-way of the long length. (see below) There is a wood frame covered by ceramic tile that the tub sits in, it appears there are some 2X4 and plywood supports underneath it as it sits on the subfloor. Our MBR is above the garage like a bonus room would be, so the tub is above the garage which is completely finished with drywall. I've ruled out it being an issue of water height. With my wife in the tub- jets on or off, with the waterline just below the overflow, the water doesn't appear. If I am in it with the waterline at the same height (less actual water), the water appears on the tile floor of the bathroom but is not leaking into the ceiling below- or doesn't appear to be- there is no wetness or water stains on the garage ceiling.
nashvillebill is offline   Reply With Quote
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Bathroom 'wet floor' - floor slope options Couch Plumbing 9 03-11-2008 05:42 PM
Bathroom Floor Caving In mherrington111 Flooring 6 01-21-2008 10:27 AM
old uneven bathroom floor toubob Flooring 4 02-15-2007 02:39 PM
