Whirlpool Tub Installation - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2009, 07:04 PM   #1
I'm installing a fiberglass whirlpool tub. The directions specifically say the tub is designed to be held up by the outside of the tub not the floor. I've installed 2x6 ledger board on the long wall, a 2x4 on the rear wall and a 2x2 on the front wall. It just doesn't seem to be enough to support a tub that'll hold 75 gallons of water. I only used smaller boards because the motor or overflow were in the way so I couldn't use wider boards.
Is anyone else concerned or should I be ok?
MikeyP is offline   Reply With Quote
Old 01-12-2009, 07:09 AM   #2
Remodeling Contractor
If you securely fastened the ledger board, your support should be fine. If you feel you want more support, set the tub into a few bags of wet plaster
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
Relocating drain/trap in manufac. home for whirlpool, HELP!!! MikeVila Plumbing 7 12-10-2008 09:04 PM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
