Whirlpool Gas Water Heater Thermocouple Replacemnt - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-20-2012, 07:04 PM   #1
Rewards Points: 77
Hello, I need to replace the thermocouple. Looked easy enough but when I removed the manifold door the gasket fell apart and the top half was burned up. How important is the gasket. Could I use a hight temp rtv sealant like the red sealant to make a new gasket. Do you professionals normally know to keep a spare replacement gasket on hand when you replace a thermocouple?
SS396 is offline   Reply With Quote
Old 06-21-2012, 04:12 PM   #2
biggles's Avatar
model number on the heater if possible the inspection cover should just pull up and out.. if the flame is rolling out might want to check the draftand flue connection going out.typical is this YOU TUBE
Old 06-22-2012, 04:42 PM   #3
Rewards Points: 77
Biggles, Thanks for the reply. model nbr is BFG1H5040T3NOV. Whirlpool with flame lock. That is why the gasket. The manifold door is held in place with a couple of screws and had this foam gasket seal. I wanted to get back in business so I used the 650 deg rtv sealant. (on one side so I could get it back off when the time comes.) The original foam gasket sure doesn't look to be high temp anyway. I ordered the correct gasket from Whirlpool but I don't know if I will even bother with it when it is delivered.
Coincidently you are spot on about the draft. A few days ago I found a dead bird in the water heater flue pipe. Thanks
Old 06-22-2012, 07:20 PM   #4
biggles's Avatar
if that isn't an induced draft HWH style with a flue fan a quick test to verify the flue up and out is drafting is.....where it connects on top that space is the draft mix no heat should be rolling out of there.then striking a match the flame/smoke should draft up the flue thru that opening..
Old 06-23-2012, 07:18 PM   #5
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
i believe Whirlpool and most w/h manufactures require replacement of the pilot assembly it has everything cant remember what brand on there flame guard models there thermocouple has left hand threads you will need the conversion kit comes w/everything except the actual burner and orifice, and has the thermal cut off which connects to control valve thermocouple inlet ,check yours to make sure ok
wctekkk is offline   Reply With Quote
Old 06-23-2012, 07:33 PM   #6
sacramento plumber
wctekkk's Avatar
Rewards Points: 77
i was just thinking your has what i call a black clip it's the part were the pilot tube and themocouple go through door if so your thermocouple may have a built in resistor you can very easy the thermcouple is thin were it connects to control valve then inside combustion chamber it gets fatter ii'm sorry i'm having a hard time explaining not the sharpest tool in shed if so u will need pilot assembly
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
My water heater (Whirlpool 50 gallon model #EE2H50RD045V) will not heat water FastXD Electrical 8 02-03-2009 09:58 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
